Quick-change toolpost for a Zyto lathe - what size?
David Jenkins 405/06/2022 18:00:38
10 forum posts
I am busy bringing my Zyto 3.375" lathe up to a useable state, and I've managed to get it working very nicely with a VFD.
My next mission is to look for a quick-change toolpost system, but I have absolutely no idea about the best size to get. Has anyone with the same lathe fitted a QC post and, if so, which one did you get?
Brian Wood06/06/2022 09:48:54
2742 forum posts
39 photos
Hello David,
I imagine it will be of similar size to the ones that fit Myford lathes and suggest you look at those.
Regards Brian
David Jenkins 406/06/2022 09:52:21
10 forum posts
Old Myfords, perhaps (ML1, etc) but not sure whether the centre height being 1/8" lower would make a difference?
DiogenesII06/06/2022 10:24:11
859 forum posts
268 photos
That really depends on the height of the topslide 'deck' relative to the spindle centre - IIRC an ML7 has 5/8"..
David Jenkins 406/06/2022 10:28:05
10 forum posts
I'll have to go and check it!
Thanks for the info.
John Hinkley06/06/2022 11:11:12
1545 forum posts
484 photos
David,
As has already been said, it is all a matter of measurement. Take into account the size of your tooling, height of the toolpost mounting surface to centre height and compare with the dimensions for a given QCTP. For example, my lathe is a generic 9 x 20 Asian clone and I use a model 000 wedge-type from Uncle Ketan's Emporium. I'm very pleased with it. Have a google for videos on YouTube. There are several on there that explain the method of selecting the correct size.
Wedge-type QCTP Model 000
That page also has links to articles on fitting such a toolpost to either a mini lathe or a Myford, so I'm pretty sure that size would suit your Zyto.
I dare say you could get away with a larger one, but I don't see any benefit to be gained by doing so.
Lee Rogers06/06/2022 14:12:00
203 forum posts
I have the small Myford compatible Dickson from Chronos on my Drummond B Type .which is a bit heavier than the Zyto but comparible, Its fine for most everyday lightish jobs but I still keep a simple shimmed holder for''heavy'' work without the topslide , the key being the extra rigidity. Heavy is of course a relative term but I'm sure you get the gist .
