Emco Compact 5 Modifications
Graham Meek15/05/2022 11:16:37
714 forum posts
414 photos
After deciding to downsize my workshop in January, the need to get the Compact 5 (C5) up to a standard I was comfortable with became a priority. The use of my larger machines would be of benefit while they were still here.
Having had the luxury of the Screwcutting Clutch on the Maximat Super 11 it was something I was not happy to do without. The C5 had always been tempting me to do this mod, so during my recuperation in February I set about designing the attachment.
The above view shows the Mk1, and it also shows you really need to be in the workshop more. The reason being I had forgotten to allow for the dis-engagement of the Leadscrew. This being a necessary requirement on the C5, other wise in Manual mode the operator has to turn the banjo gears as well.
This need to retain the C5 disengagement Knob meant the Operating lever would need to move from the chosen site where the knob was to in front of the headstock. Thankfully during the need to do a complete redesign of the main body it was possible to have both controls in the one place.
The keen eyed amongst you will notice the main body is now in two halves, or parts. Again had I have been a more frequent visitor to my workshop at the time, I would have noticed the Bracket welded to the inside of the Headstock cover, which takes the cover locking screw.
Had it been possible to retract the leadscrew with drive key attached through the bearing in the lathe bed, then the original design would still have worked. Unfortunately the key stands proud of the shaft and this cannot happen. Thus there was nothing to do but start again with two halves, and yes this was after I had machined the main body in one. Of course I could have cut the bracket off, but that is not how Graham operates.
The redesign also threw up another problem, in that the Dog Clutch, because of the split line needed to sit higher in the upper part of the main body. Unfortunately this brought the dog clutch selector into conflict with the drive belts when changing to the lowest Mandrel speed. This was eventually overcome by machining a flat on the selector similar to the flank on a camshaft. An eccentric balance weight is yet to be made and fitted to the outer end of the selector shaft.
A new bearing assembly was also made for the Leadscrew handwheel which has some Radial ball bearings in. The housing was extended towards the Headstock to provide the anchor point for the outer Trip Rod support. The ball bearings will eliminate wear to the leadscrew end face and give better repeatability when screwcutting.
While I have used this lathe for screwcutting in the past, it was a rather hair raising experience. This attachment now completely eliminates the heart stopping moment as the tool approaches the chuck jaws.
I will in due course go on to describe other attachments for the C5, two of which get the benefit of the screwcutting clutch. I hope you have enjoyed my rather long winded post.
Gray,
Edited By Graham Meek on 15/05/2022 11:20:55
Edited By JasonB on 30/06/2022 20:35:31
Kiwi Bloke16/05/2022 06:55:10
912 forum posts
Hi Gray. Inspired and inspiring! When I saw your post announcing your intention to down-size, and to concentrate on the Compact 5, I was tempted to ask facetiously whether we would be seeing a full screw-cutting gearbox, with leadscrew single dog clutch for it. I didn't because downsizing decisions are too often the result of adverse circumstances, and I certainly didn't wish to be insensitive. However, it seems you're well on the way to elevating this machine from near-toy level to Serious Machine status, so perhaps the question is now part-answered... I'm sure we're all going to be fascinated by developments.
It seems to me that the Compact 5 has serious design defects, predisposing it to problems resulting from wear, that warrant attention, perhaps before embarking on complicated enhancements - well, that's true of my machine, at least. Have you any interest in re-engineering the cross-slide feed 'nut', which, on earlier machines, is cut directly into the saddle, and is neither adjustable nor replaceable? Also, will we see leadscrew half-nuts and saddle handwheel feed, as (IIRC) hinted at in a previous post?
Edited By Kiwi Bloke on 16/05/2022 06:57:43
Joseph Noci 116/05/2022 07:19:18
1323 forum posts
1431 photos
Very nice work as usual Graham. I was not aware of your trials and do wish you well.
Difficult to lose the Super-11...I trust you will always have a place for the FB-2 though..
From the machining marks on the Clutch upper body it seems the process was carried out under CNC control? As usual, a complex piece done well! Keen to see it come together.
Joe
Graham Meek16/05/2022 11:02:07
714 forum posts
414 photos
Hi Kiwi Bloke,
Thanks for your kind comments, there were times when I nearly abandoned the whole idea. Thankfully things are now on the up and life goes on.
I'd like to take the opportunity to mention that I don't think a lot of people realise the cross-section of the C5 Bed ways are identical to the Unimat 3/4. I recently posted on here, about the restoration of a Unimat 3 that was given to me. It was a bit of a basket case and was fitted with a large induction motor all suspended off the headstock.
Despite the obvious abuse to this machine in it's life, there was zero wear on the bed ways. The Tailstock and Cross-slide assembly were worn but the wear was nothing like I was expecting.
Fortunately Emco saw the light with my C5 as this one comes with an adjustable / replaceable cross feed nut. The Leadscrew nut also benefits from a backlash adjustable feed nut. The trip-rod bracket is anchored off this adjustment screw.
Thus I think given my intended use for these two machines I don't see wear being a problem.
I did draw-out such an apron attachment some while ago, but as yet I have not got around to making it.emco compact 5 handwheel conversion p1.jpg
Whether I ever will, is another story, I might if I get the chance to obtain another C5.
Gray,
Hi Joe,
As mentioned above things are on the mend now, so I am doing OK thanks. The C5 project has been a God send really, if a lot of very hard work given the timescale I set myself.
Unfortunately the FB2 is going as well. While it will be hard to see both of them go, it has to be done sometime. Better to do it while I am able to. The machines will make someone else happy and I hope they get as much enjoyment out of them as I have had. I am really looking forward to using the smaller machines, I started out with a Unimat SL 64 years ago.
As regards the CNC, sorry appearances can often deceive. Everything was done by first principles and the trusty Emco Rotary table. Total machining time was just over two days.
Gray,
Graham Meek17/05/2022 09:21:01
714 forum posts
414 photos
One thing I did forget to mention is that the gears were made using the Emco Compact 5 Dividing attachment and are all 1 MOD.
Gray,
Jouke van der Veen17/05/2022 14:38:18
203 forum posts
19 photos
Dear Graham,
Your design of the Emco C5 looks for me an interesting extension for the lathe.
What I not yet fully understand is the working of the engagement/dis-engagement mechanism.
Another (remaining) question is if the handwheel could be placed to the right hand side of the saddle so that the latter can move closer to the headstock.
Jouke
Graham Meek18/05/2022 10:22:33
714 forum posts
414 photos
Dear Jouke,
Stops on the trip rod running along the front of the machine can be set to any desired thread length, with-in the limitations of the machine. The trip rod moves to the left or right depending on the operating lever position. Which dictates whether the the thread is a RH or LH. Moving the operating lever to the right means the trip rod moves to the left and visa versa.
The operating lever works the banana shaped plate, at one end of this is the trip rod and at the other is the dog clutch selector. Thus any movement of the trip rod directly affects the dog clutch selector.
As the carriage moves along the bed during screwcutting it makes contact with the stop, 2.5 mm later the dog clutch is disengaged. Moving the operating lever in the opposite direction, after withdrawing the tool, returns the carriage to the start position.
As there is only one tooth on the dog clutch it can only pick up the drive at one pitch intervals.
Regarding the hand wheel position, this end was chosen so as to utilise the existing leadscrew nut fixing position and to retain the original operating force position on the carriage.
In my experience there is always a dead space at the headstock end of the bed due to the chucks, faceplate and catch plate attached to the mandrel. I therefore did not consider there would be much loss of travel. However in this instance I may be wrong.
I hope these notes help,
Gray,
PS
I have just completed a new topslide feedscrew using the above attachment, I hope to post a photograph soon. Which is for the next phase of the mods, a Retracting Topslide.
Jouke van der Veen18/05/2022 20:07:57
203 forum posts
19 photos
Dear Graham,
Thank you for your extensive information. I have to study this.
Concerning the engagement/dis-engagement mechanism there could be some misunderstanding.
I meant the design of the engagement of the saddle to the leadscrew in combination with the handwheel (not for the screwcutting at the left end of the leadscrew, which I have to study).
I have now a complete Emco C5 with an adjustsble cross feed nut and an extra bed with saddle + crossslide without adjustment. The latter is used as cross table for the Emco C5 milling column. I had some ideas to replace the non-adjustable nut but I am also (slowly) working on a motor driven cross slide. In this case a cross feed screw is fixated in the saddle and a stepper motor with a hollow shaft attached to the front of the cross slide is running on the screw. The hollow motor shaft should then contain an adjustable nut rotating on the steady cross feed screw. Alignment of the steady screw and cross slide/motor movement is a major issue. I hope this description is clear.
I am interested in improvement of my Emco C5 but I hesitate to make irreversible changes (in other words: damage) to original Emco parts.
Jouke
Graham Meek19/05/2022 10:06:14
714 forum posts
414 photos
Dear Jouke,
The leadscrew engagement on the Handwheel conversion is carried out by the lever on the left-hand side of the carriage. This lifts a cylindrical half nut via an eccentric into engagement with the leadscrew. The cylindrical half nut is keyed to stop it rotating so alignment with the leadscrew is always assured. (One half nut has been used on numerous occasions in the past by various lathe manufacturers).
While your C5 powered cross feed sounds an elegant design. I think if I were trying to do this I would start with a C5 CNC cross slide and carriage assembly. These regularly come up on the Internet for sale. I think this would be an easier starting point. A plus point is these parts are, I believe, made from Cast Iron.
With regards to my design modifications. I pride myself in that I do not modify the existing machines in any way. I always make use of existing tapped holes for attachment points. No existing Emco part was modified in this recent design and my C5 could be put back to standard in a matter of minutes.
Gray,
Graham Meek20/05/2022 16:47:32
714 forum posts
414 photos
Work has ground to a halt on these projects for a short while. I need to spend time getting the larger machines out of the workshop.
As a taste of what is coming I have enclosed one of John Slater's 3D views of the Retracting Topslide attachment.
Since John has made this drawing I have moved the Operating handle to the other side of the unit. That way it does not foul the Tailstock.
Gray,
Graham Meek28/05/2022 10:27:14
714 forum posts
414 photos
Despite the workshop being in mess due to the larger machines going. I have had a chance to make the new Topslide Feed screw and the Main Body for the Retracting Topslide.
This was machined on the C5 from a long old 10 mm bolt. I find this material machines well and screw cutting is a pleasure. As was using the Screw cutting clutch on the C5. Of course it would have been quicker with the retracting topslide.
The Main Body was machined on the new Proxxon Mill and after locating all the holes by co-ordinates the bores were finished on the C5 using the 4 Jaw chuck.
Gray,
Graham Meek30/06/2022 16:40:02
714 forum posts
414 photos
Now I have the workshop almost straight I have taken a breather and done some more machining.component parts of c5 rt.jpg
These are all the parts laid out ready for assembly. Below is the finished attachment fitted to the lathe.
This is the fully forward position, note the position of the topslide end with regards to the aluminium topslide base.
This view shows the slide fully retracted, the distance moved is 4 mm. Due to the longer feedscrew bearing the topslide has a much smoother action now.
I am hoping when I post the next photographs it will show the slide in use. It will be cutting a 10 TPI worm gear. This will be part of an attachment to bolt directly to the C5 Dividing attachment which will give this attachment a conventional 40:1 Dividing facility. This however is a way off as yet as I have the table feed for the Proxxon mill to finish first.
Gray
Graham Meek26/07/2022 12:57:25
714 forum posts
414 photos
I thought those Compact 5 owners with cross slide feedscrew backlash problems might like to see what was in my post from Emco Holz & Hobby this morning.
This is a brand new part and machined from the solid. It utilises the newer inserted feedscrew nut with backlash elimination. I think most of the feedscrew parts are available separately.
The underside view shows the bearing surfaces to be continuous not as in the original die cast version, which had pockets moulded into the bearing surface. Because there is now probably more bearing surface the width of the Carriage has been reduced by 15 mm. From what I can tell most of this is taken off the front edge of the carriage.
Gray,
Jouke van der Veen26/07/2022 16:06:47
203 forum posts
19 photos
Hallo Gray,
I know this solution for the thread wear-out in the original carriage without adjustable feedscrew nut.
Emco introduced a cast solution for it in 1985. For that solution you needed also a longer cross-slide and a longer spindle compared with the originals from before 1985. See the Emco Compact 5 manual.
My question is now: can you use the original shorter cross-slide and spindle for this solid carriage (because width is reduced by 15mm)?
Jouke
Graham Meek27/07/2022 11:00:26
714 forum posts
414 photos
Hello Jouke,
My wording of the actual reduction in width, may have mis-led you somewhat. The dimension from left to right of the carriage, the bit that sits parallel to the lathe centreline has been changed from 115 to 90 mm.
I was aware of the changes made during the Emco upgrade, and I think my ball bearing version for the cross-slide Handwheel Bracket will restore the correct travel on the earlier lathes. As well as giving an improvement to the cross-slide handwheel bearing.
Gray,
Jouke van der Veen27/07/2022 14:42:15
203 forum posts
19 photos
Hello Gray,
Thank you.
There was already some doubt about what you would mean with width of the carriage.
I keep following you with all your nice improvements on the Emco C5. Most of them, however, are “out of my range” to introduce on my own C5.
I know somebody here in The Netherlands who bought the new carriage as well. I am not sure if he fitted it already to his C5. I will send him a link to this topic.
Jouke
Jamie Wood27/07/2022 15:53:35
19 forum posts
8 photos
Personally I think Neil should dedicate a whole issue just to your Emco related mods Gray!
I too have thought about adding a thrust bearing into a cross-slide bracket or handwheel to improve that situation.
I also didn't realise you could still buy new carriage units from Emco, mine must be pre 1985 as it doesn't have the backlash adjuster. I will have to look that up for a future project, do you mind me asking what the rough cost is with postage and customs these days?
Thanks,
Jamie
Howard Lewis27/07/2022 16:02:22
7227 forum posts
21 photos
It is very good that Graham has the knowledge, skill and courage to improve a machine.
It may lack a feature that he needs, or that has been omitted for reasons of cost, or lack of foresight by the designer.
Good for him to design such improvements /modifications, and to such a high standard.
Have to say that envy of such dedication is high on my list of descriptions. of such work
Graham Meek27/07/2022 17:12:41
714 forum posts
414 photos
Hi Jamie,
Some how I do not see your first sentence coming to fruition, but it is a nice thought on your part.
I am just in the process of making a Jpg of the drawing for this Handwheel bearing mod, maybe I can post it later today.
As regards the spares there is a considerable amount still available, even a new lathe Bed. There are two different versions as regards the Carriage, one Metric and the other Imperial. The cost at the moment is 108 Euro's for the metric one. Which I thought was good value for a new part. Postage is about 28-29 Euro, and as regards the import duty I think this is on a sliding scale. How it is worked out I have not got a clue. My order came to more than the above 108 Euro, and of course they have to add in a "Handling Charge" which was £12 on its own in my case. You actually pay Parcel Force what is due.
I hope this helps?
Gray.
Hi Howard,
I am humbled by your comments.
My Father was responsible for the standard of work I produce. He gave me the desire to always look to do a better job and the skills to do it with. Plus I had some of the best training available during my apprenticeship.
Having been used to a better machine in the Maximat Super 11, the Compact 5 is now reaching a standard at which I am more than happy with. This machine continues to surprise me as regards it's accuracy, what work it can do and the finish it produces. Obviously you do not watch the clock as things take a bit longer than they did, but I am beginning to enjoy my machine time more.
Gray,
Graham Meek27/07/2022 17:37:34
714 forum posts
414 photos
Here is the drawing for the Ball bearing C5 Endplate. To make things simple the bore goes straight through and an internal circlip provides the abutment face for each bearing.
I hope this has come out OK. If there is a problem perhaps one of the Moderators can upload a PDF which I can do easily.
Gray,
