Milling Southampton area?
Chris Stevens 208/05/2022 17:47:11
2 forum posts
I wonder if there is anyone close to Southampton, who might be able to help with milling SOHC Honda cylinder heads, to accept camshafts fitted with a bearing, rather than running directly in the head? Have a few I need doing, and could be more in future. TIA to anyone who responds to this.
Chris Evans 608/05/2022 19:45:05
2156 forum posts
I can't help being up in the midlands but are we looking at car or motorcycle application ?
Chris Stevens 208/05/2022 19:59:28
2 forum posts
Single cylinder Honda motorcycle engines, Chris. Wear is very common on these heads, but as most check them without releasing tension on the cam chain, the play/wear doesn't get detected that often.
John ATTLEE09/05/2022 10:02:24
49 forum posts
I am between Petersfield and Portsmouth. I have a Victoria U2 milling machine.
Why not make some tooling (which might need a milling machine) and line bore using a lathe with the line boring tool running between centres and the tooling replacing the compound slide? That should keep the set up time down.
Happy to chat on 'phone.
