machining a t5 pulley
fabio manganelli29/04/2022 00:25:41
7 forum posts
hi
I am not sure this is the right forum section anyway ..
I need to machine an 80 teeth pulley. I am using gearotic to figure out the outside diameter of the blank but, after an extensive search on the web, I am still unable to figure out the correct profile of the cutter. it is possible that I am not so good finding it but ..
Yes I would like to grind myself the cutter having the means to do that.
Anyone has informations on the correct tooth profile of a t5 pulley?
many thanks
cheers
Fabio
Hopper29/04/2022 04:34:09
7881 forum posts
397 photos
If you google "T5 pulley tooth profile" you will have a choice of suitable information.
Also, "T5 Pulley Dimensions" or "T5 Pulley Specifications" will give more information on diameters etc.
John P29/04/2022 09:31:50
451 forum posts
268 photos
Hi, Fabio
If you look at hpc gears and the T5 pulleys it will give you
the sizes for PCD and pulley OD .
https://www.hpcgears.com/
The calculation is for example your 80 tooth pulley is
80x 5 = 400 divided by Pi 127.33mm = PCD
127.33 - 0.83 = 126.50 mm pulley OD.
Looking here will give you the pulley tooth belt profile.
https://us.misumi-ec.com/vona2/detail/110300406820/
An article Form relieved toothed belt cutters published
MEW 164 June 2010 shows toothed belt cutters
made using the Eureka form relieving tool which may be
of some interest.
I have recently done something similar using a ground fly
cutting tool to cut 1/5 XL pulleys the photo here
shows a 66 tooth pulley being flycut / hobbed
takes about 4 minutes to cut all the teeth.
A gear tooth caliper is a useful thing to have when grinding
these sort of profiles ,they can be had from China these days
for around £25.
fabio manganelli29/04/2022 18:28:07
7 forum posts
Thank you very much, I have found what I was looking for.
I will be using a Deckel clone single lip grinder to produce the tool and I will post the results here as soon as possible.
Thanks
Fabio
