AJW | 08/04/2022 18:02:00 |
![]() 388 forum posts 137 photos | Planning on using my launch boiler to supply a horizontal stationary engine. It's a copper water tube unit about 10 inches long by 5 inch diameter with a 2 1/4 inch flue fitted with 8 water tubes. Looking inside through the safety valve bush it looks quite green and dirty. It was made by a family member back in the 60's. Always steamed well and was heated by a paraffin (blowlamp) type burner. I've always dried it out after use, many moons ago but I don't suppose it was before I inherited it! Was going to dose it with citric acid - what do the panel recommend?
Alan |
Jon Lawes | 08/04/2022 18:06:16 |
![]() 1078 forum posts | I've used white vinegar in the past with good results. |
SillyOldDuffer | 08/04/2022 18:23:11 |
10668 forum posts 2415 photos | Citric Acid will clean it up, but won't stop further corrosion. (Repeatedly cleaning with Acid will eventually damage the boiler, but it will take years.) The pro's protect out-of-service boilers by stopping Oxygen and Water from coming together. Either:
For home purposes, I guess careful drying and sealing is good enough. Fairly obvious leaving a boiler with water in it, and allowing air free access will cause oxygen rich condensation to do it's worst. Dave |
