Andrew Honychurch | 25/03/2022 19:14:52 |
19 forum posts 10 photos | This beautifully built loco has been in my late fathers workshop for maybe 50 years . Dad was a steam enthusiast and Myford main dealer and bought many bits back from families over the years. I would love to find out which engine and plan she is so maybe I can see it through. The Engineer who built this was amazing |
roy entwistle | 25/03/2022 19:53:02 |
1716 forum posts | A photo would help Roy |
Andrew Honychurch | 25/03/2022 19:54:41 |
Edited By SillyOldDuffer on 25/03/2022 21:02:13 |
Andrew Honychurch | 25/03/2022 19:55:16 |
Edited By SillyOldDuffer on 25/03/2022 21:02:37 |
Andrew Honychurch | 25/03/2022 19:55:39 |
Edited By SillyOldDuffer on 25/03/2022 21:03:09 |
Andrew Honychurch | 25/03/2022 19:56:55 |
19 forum posts 10 photos | I am sorry , the photos are all to cock. Its not a very easy forum to post on! apologies but if anyone would like better photos please email me at [email protected] and i will send some. thanks |
Andrew Honychurch | 25/03/2022 19:57:45 |
Edited By SillyOldDuffer on 25/03/2022 21:03:43 |
Andrew Honychurch | 25/03/2022 19:58:14 |
Edited By SillyOldDuffer on 25/03/2022 21:04:05 |
Andrew Honychurch | 25/03/2022 19:58:52 |
Edited By SillyOldDuffer on 25/03/2022 21:04:25 |
John Baguley | 25/03/2022 22:18:39 |
![]() 517 forum posts 57 photos | Looks like a Great Western 4-6-0 of sorts with the inside Stephenson valve gear and the pendulum levers driving the outside valves but don't know the design off hand. The tender doesn't look Great Western though so may not be for that loco. What gauge is it - 3½" or 5" ? John |
Andrew Honychurch | 25/03/2022 22:36:11 |
19 forum posts 10 photos | Thank you for the reply John. The tender is not for that engine and should not be in the post. The engine is 5 inch I think it has been built in the 60s . Would it be scratch ? It looks too good to my untrained eye Edited By Andrew Honychurch on 25/03/2022 22:36:49 |
JA | 26/03/2022 14:13:24 |
![]() 1605 forum posts 83 photos | Bump. Because I want to hear what it is. JA |
Andrew Honychurch | 26/03/2022 14:18:28 |
19 forum posts 10 photos | It has been suggested to me elsewhere that it is Torquay Manor by Martin Evans. Before I buy the plans I wonder if someone who has them could give a copy of some of it I can check off against my engine please ? |
John Baguley | 26/03/2022 15:50:37 |
![]() 517 forum posts 57 photos | No, it's not a Torquay Manor. There are too many differences in the frames etc. I've just had a look on Station Road Steam and It looks very much like a GWR Hall that was sold some years back - Stock Code 2663 if you want to look. The position of the weighshaft and the pivot for the rocking levers that drive the valves are identical. Most GWR locos have the pivot for the rocking levers (pendulum levers) on the top of the frames but this one has them in the middle of the frames. I'll see if there was a commercial design for the Hall in 5" Gauge. John PS - Just found an identical chassis on SRS - stock code 5006 - so it must have been a commercial design. It's just a case of finding which one! Edited By John Baguley on 26/03/2022 16:00:24 |
Brian G | 26/03/2022 16:46:48 |
912 forum posts 40 photos | Maxitrak can supply drawings from the Greenly archive, perhaps you could buy the GA sheet for his 5" Hall and see if yours matches? Brian G |
John Baguley | 26/03/2022 16:48:09 |
![]() 517 forum posts 57 photos | Ok, think I've found it. It's a design by Henry Greenly from the 1930's.There is a short article about the loco in ME Volume 80 Issue 1987. The author isn't named but I would say that it was by Greenly himself. He designed the loco for two gentlemen for their second loco build. If you pm me with your email address I can send you a copy of the article. The drawings should be still available from Maxitrack as they hold the Greenly archive of his drawings. There are 10 sheets in all. You won't be able to get any missing castings anymore unless you make patterns and get them cast your self but you should be able to get by without. You have the major castings e.g. wheels and cylinders anyway. John Brian just beat me to it! Edited By John Baguley on 26/03/2022 16:49:10 |
Andrew Honychurch | 26/03/2022 17:01:27 |
19 forum posts 10 photos | Brian and John , thank you very much indeed for your help with this. I am super pleased to put a name to the loco and will endeavour to see what drawings I can get. As suggested maybe buying just one ( GA?) would help me identify it. If either of you wish to send me an e mail address by pm I will send you better photos I have of the locomotive. Thanks again, Andrew |
Brian G | 26/03/2022 19:13:08 |
912 forum posts 40 photos | Hi Andrew I'm not sure sending me any photos would help as I know almost nothing about large scale or GWR locos. I did however find something that may be useful. Take a look at this website The Steam Workshop which shows a example of a Greenly Hall. The first photo in the fourth row seems to me to show a rocker in the same place as yours. I have snipped this from the image. Brian G (Edited to remove rogue smiley - this forum seems to breed them) Edited By Brian G on 26/03/2022 19:14:31 |
Andrew Honychurch | 27/03/2022 15:19:52 |
19 forum posts 10 photos | Thank you again Brian. Its good of you to help me with this. Now I need to consider whether I can see this engine through to build it out. I would like to and in many ways a lot of the work has already been carried out. I wonder whether the pistons will be with conventional rings or rope seal. If the former I assume it would be better to re engineer with rings? |
Weary | 27/03/2022 16:16:53 |
421 forum posts 1 photos | Hello Andrew, The cylinders on your locomotive appear (from the colour shown on-screen) to be gunmetal. If this is the case then retain 'soft packing' or, maybe alternatively fit 'O' rings. This second option would almost certainly require new pistons. Worth bearing in mind that there is nothing 'wrong' with graphite impregnated yarn, or PTFE, etc., as piston sealants. They provide good service. In my opinion.
To answer your further question posed on MECH website about completing the locomotive (& to try and keep most of the 'general info' in one place): As John Baguley has written above you have all the most 'awkward' castings (i.e. loco wheels & cylinders) already machined and fitted. Anything else can be fabricated or made from solid etc. The Great Western (GW) were exponents of standard fittings so castings from other designs may well be appropriate. Similarly a tender (and associated castings) from another GW design may be suitable. I'm not a GW 'enthusiast' myself so cannot advise; MECH, where there are some extremely knowledgeable posters, is the place for that kind of detail information. Regards, Phil Edited By Weary on 27/03/2022 16:31:03 |
