Jasper Bower | 20/03/2022 14:04:28 |
10 forum posts 2 photos | Hi, I have an RDG 30VSM which has mashed its gears. Could someone please point me in the direction of where to get replacements, please? Looking at the forum, it seems they are similar to the Warco WM16, but the gearing looks different? Thank You. https://www.ebay.co.uk/itm/113999695630 |
Dave Halford | 20/03/2022 17:36:04 |
2536 forum posts 24 photos | Have you tried RDG ? |
Jasper Bower | 20/03/2022 17:40:26 |
10 forum posts 2 photos | I have emailed them and await a response. |
Jasper Bower | 21/03/2022 13:37:47 |
10 forum posts 2 photos | Unfortunately no joy. The answer was "we got them from the same places as Warco". |
Ian Parkin | 21/03/2022 14:39:42 |
![]() 1174 forum posts 303 photos | Isn’t a 30 the same as a wm 18? if so i think i have a spare off to look now… |
Ian Parkin | 21/03/2022 14:47:06 |
![]() 1174 forum posts 303 photos | Is it a 56 and a 31 tooth? if so i have one |
Howard Lewis | 21/03/2022 14:58:40 |
7227 forum posts 21 photos | You can get an idea of what gears you require by measuring the OD of the mating gear, and counting the teeth, as well as the other dimensions.. The gears are likely to be Module, so Diameter in mm / (Tooth Count + 2) i= Module. EXAMPLE OD = 27.5 mm / (20+2 ) = 1.25 (Module ) for a 20 tooth 1.25 Mod gear. The answer may well be 1.5, 1.25 or 1. You could look at other importers to see if they import a similar machine (Possibly only in a different paint scheme) who could supply a replacement. Likely places, once you have measured the gears, and knowing the tooth count of the damaged gear, might be Chester, Axminster Arc Euro, SPG, Amadeal etc. Bear in mind that some machines, although superficially identical, may differ in detail. Depending on the manufacturer,, the keyway, for instance may differ, (Say 4 mm against 3 mm), If all else fails and only the bore is different, you might have to bore out and bush a close approximation to get the machine running again. Ultimately, you could approach someone like HPC, or Davall or Reliance gears, but their gears are likely to be costly and need modification to fit your machine. The only other advice that I can give is not to work the machine quite so hard in future The plastic gears are the weak point in the drive train and fail safe to protect other components, akin to a shear pin.. These are hobby machines, not industrial machines designed to be worked hard 8 hours every day! Howard |
John Baron | 21/03/2022 16:14:26 |
![]() 520 forum posts 194 photos | When that gear got damaged on my mill, I went to HPC and bought steel gears and made my own replacement ! In my case quieter as well. The moulded gear was off centre and made a thumping noise as it ran.
Jasper Bower | 21/03/2022 19:24:45 |
10 forum posts 2 photos | Posted by Ian Parkin on 21/03/2022 14:47:06:
Is it a 56 and a 31 tooth? if so i have one The single Large Helical is 39. Large is 56 Fixed to 30 |
Jasper Bower | 21/03/2022 19:25:23 |
10 forum posts 2 photos | Posted by Ian Parkin on 21/03/2022 14:39:42:
Isn’t a 30 the same as a wm 18? if so i think i have a spare off to look now… Thank You. I do not know! |
Packmule | 23/03/2022 12:39:44 |
133 forum posts 6 photos | Know anyone with a 3d printer ?
Jasper Bower | 23/03/2022 19:53:51 |
10 forum posts 2 photos | Posted by Packmule on 23/03/2022 12:39:44:
Yes, if someone has the .stl files? That would be fantastic
Packmule | 25/03/2022 22:22:18 |
133 forum posts 6 photos | If you look on thingiverse for G0704 gears there are both spur & helical listed , may fit |
Jasper Bower | 26/03/2022 09:06:47 |
10 forum posts 2 photos | Posted by Packmule on 25/03/2022 22:22:18:
Thank you.
Jasper Bower | 26/03/2022 10:00:54 |
10 forum posts 2 photos | Having no luck at the moment with gears, I am looking at fitting an AC motor with belt and pulleys. The current DC motor is 1100W, what is the AC equivalent please? Any links to suitable belts? Thank You. |
Ian Parkin | 26/03/2022 10:20:29 |
![]() 1174 forum posts 303 photos | Are you sure on the fixed pair of gears? i have a set off a 30vsm spare and they are 31 and 56 and the helical is 39 |
Jasper Bower | 26/03/2022 10:38:44 |
10 forum posts 2 photos | Hi Ian,
I have messaged you. Thank You |
Jasper Bower | 26/03/2022 10:47:17 |
10 forum posts 2 photos | Posted by Ian Parkin on 26/03/2022 10:20:29:
Are you sure on the fixed pair of gears? i have a set off a 30vsm spare and they are 31 and 56 and the helical is 39 Having recounted. You are correct! that gearing is what I need. THANK YOU!! |
