Peter Simpson 3 | 03/03/2022 17:24:04 |
122 forum posts 2 photos | I need to carry out a repair on my Boxford shaping machine vice. The original has a two small sections of the movable jaws fractured off. I intent do fabricate the whole movable jaw, which will require new dove tails to be machined. A length of 60mm square cast iron would be the starting point but I'm unsure which grade to purchase M-Machine do GR17 and SG. Which grade be more suitable ? |
Bazyle | 03/03/2022 19:08:28 |
![]() 6956 forum posts 229 photos | GR17 is your basic cast iron with flakes of graphite that make it softish, easy but messy to machine, break if you hit it hard but cheap. All those flakes or graphite are stress raisers which make it more breakable under bending or stretching but don't matter when squashed. |
old mart | 03/03/2022 19:16:11 |
4655 forum posts 304 photos | The SG iron has two advantages, the much lower brittleness which means your replacement will be superior to the original, and the very much nicer swarf which is more like steel swarf. |
