How to remove a SMD resistor
modeng200024/02/2022 17:33:07
340 forum posts
I would like to be able to remove a SMD chip resistor. Unfortunately it has been fixed with adhesive and soldered. I assume the adhesive won't soften with heat so what is the best way to approach this?
Martin Connelly24/02/2022 17:38:48
2549 forum posts
235 photos
The controls department where I used to work used a hot air tool specifically designed for this type of thing. Looks more like a soldering iron than a hairdryer.
Martin C
Joseph Noci 124/02/2022 17:53:56
1323 forum posts
1431 photos
Heat does work even if the adhesive is epoxy, etc. Use 20-40watt iron with a tip that can cover both ends of the SMD, put a blob of solder on the tip and apply to the smd - keep it in contact with both ends for 10-15sec. Use a small jewellers type screwdriver to gently prod at the smd every few seconds - it will move away..
This will not work well if the PCB is phenolic/resin impregnated paper, etc - works fine on fibreglass pcb's - FR4, etc.
Hot air may work, but will take longer and will heat the surrounding bits more than necessary.
modeng200024/02/2022 19:41:13
340 forum posts
Thanks both for your helpful replies. The pcb is fibreglass so I'll give it a try.
Andrew Johnston24/02/2022 20:06:27
7061 forum posts
719 photos
How big is the resistor and what sort is it? For standard thick film chip resistors I use two 80W irons, one on each end. Even with glue once the solder is molten the resistor can be removed by pushing gently with the irons.
Grizzly bear24/02/2022 20:08:33
337 forum posts
8 photos
How To Remove Surface Mount IC/smd IC - Learn 4 Neat Methods - YouTube
Good luck ...........
noel shelley24/02/2022 21:25:33
2308 forum posts
33 photos
I would use hot air, especially to fit a new one. Use foil to protect other components around the site.Noel.
Edited By noel shelley on 24/02/2022 21:27:36
modeng200025/02/2022 10:52:58
340 forum posts
The resistor is approx 3mm long, value 110k
I'm sure it will let go with sufficient heat on both tags.
Andrew Johnston25/02/2022 12:12:00
7061 forum posts
719 photos
Posted by modeng2000 on 25/02/2022 10:52:58:
...resistor is approx 3mm long...
Probably 1206, ie, 120 thou by 60 thou, or 3216 in metric. Huge, should be no problem removing it.
Joseph Noci 125/02/2022 13:15:54
1323 forum posts
1431 photos
Is the resistor broken/open cct? Do you need to fit a different value? If you need a lower value, put a suitable value in parallel - easier than removing the present one. If you need a larger value....
Joe
modeng200025/02/2022 20:57:14
340 forum posts
Thanks Andrew.
Joe, I believe it is o/c and will consider paralleling with a conventional resistor for test purposes if this is the case.
Not sure if there is room to leave a wire-ended resistor in place when reassembled.
