Michael Callaghan | 08/01/2022 14:38:31 |
173 forum posts 7 photos | Hi, anyone out there know who sells springs suitable for the bogies of a 5 inch gauge electric locomotive. I can’t find them anywhere. Thanks michael |
noel shelley | 08/01/2022 17:36:49 |
2308 forum posts 33 photos | Maxitrak.com /Maidstone- Engineering.com may be a good starting point or Polly Model Engineering Ltd. Good luck. Noel. |
Clive Brown 1 | 08/01/2022 21:34:07 |
1050 forum posts 56 photos | Reeves 2000 stock a range of springs that can be used for locomotive suspensions. |
duncan webster | 08/01/2022 21:46:44 |
5307 forum posts 83 photos | If you know what you want try ebay, but you'll need basic dimensions. |
Ron Laden | 09/01/2022 06:44:56 |
![]() 2320 forum posts 452 photos | If you search for die springs on ebay you will find lots of them and a wide range of lengths/diameters, they are cheap to. The springs are colour coded for the various strengths but no spec or figures only listed as heavy duty, light duty sort of thing. Its a bit of guess work getting the strength you need but being so cheap I got a couple of each for comparison and trial. I listed them as Blue - Light, Red - Med, Green - Strong, Brown - V Strong. Bear in mind though that die springs are in general strong springs so even the Blue - Light spring is fairly stiff. Ron
Edited By Ron Laden on 09/01/2022 06:46:44 Edited By Ron Laden on 09/01/2022 06:53:19 |
Michael Callaghan | 09/01/2022 15:47:22 |
173 forum posts 7 photos | Thanks chaps |
