varible speed
gordon brian davies | 29/12/2021 20:21:11 |
1 forum posts | hi, there everyone im new to this hobby which i enjoy experimenting trying to make things on my lathe, i have a anadale 210-g varible speed lathe,the varible speed does not run at constant speed when set, any one come akros the same problem? im down in carmarthenshire thanks |
Andy_G | 30/12/2021 10:38:55 |
![]() 260 forum posts | Hi, Do you mean an Amadeal 210V lathe? https://www.amadeal.co.uk/acatalog/AMAT210V.html Is the problem that the speed varies as you start to cut, or does it just run erratically, even with no load? If the latter, I would look first for sticking or worn brushes in the motor, and if there wasn't a problem there, it could be a worn control potentiometer (they're not good quality and do fail).
Pete Cordell | 30/12/2021 11:07:47 |
20 forum posts | I would give the potentiometer speed controler a clean with some switch cleaner |
