Steve Crow | 31/10/2021 14:46:58 |
429 forum posts 268 photos | A bit of help needed. Here is a picture of a spur gear differential I nicked off the 'net. My question is, if shaft A is held stationary and cage B is rotated clockwise, which direction would shaft C move? Logic and intuition tell me clockwise but I may be missing something! Cheers Steve |
ChrisLH | 31/10/2021 14:58:08 |
111 forum posts 7 photos | Logic and intuition win through! Shaft C will rotate in the same direction as Cage B (i.e. clockwise in this case) but at twice Cage B's speed. |
Martin Connelly | 31/10/2021 15:02:53 |
![]() 2549 forum posts 235 photos | The second shaft will go clockwise. It is easier to consider the case where the cage is stationary first and what is labelled as fixed goes anti-clockwise at rpm X. Then you will see that shaft C goes clockwise. In order to then see the case where the first shaft is fixed everything else has to go clockwise at whatever rpm X you imagined the fixed shaft to be going in the first case plus what it was doing in the first case. So the cage is rpm X plus zero clockwise and the output is clockwise amount plus rpm X. Martin C |
Steve Crow | 31/10/2021 15:33:40 |
429 forum posts 268 photos | Thank you Chris but I don't understand why the rpm is doubled.
Pete Rimmer | 31/10/2021 15:49:26 |
1486 forum posts 105 photos | Posted by Steve Crow on 31/10/2021 15:33:40:
In a differential whatever speed one side is slowed by is added to the opposite side. |
Steve Crow | 07/11/2021 10:46:18 |
429 forum posts 268 photos | Thanks for you help. I am ok with a bevel diff, (here's one I made earlier - **LINK**), I'm just finding it hard to get my head around the spur gear type. It's the fact that there are two gears counter rotating transmitting the power rather than a single bevel gear. Using the picture above. If cage B is fixed and shaft A is rotated once clockwise, I presume shaft C will rotate once anti-clockwise, the same as a bevel diff? If so, would putting an idler gear between the two small pinions reverse that? Cheers Steve |
Peter Cook 6 | 07/11/2021 11:21:10 |
462 forum posts 113 photos | Posted by Steve Crow on 07/11/2021 10:46:18:
It's the fact that there are two gears counter rotating transmitting the power rather than a single bevel gear. If I understand it, the two pairs of "contra rotating" pinions are not actually in mesh. The two meshing with the shaft A gears drive the cage round. The two meshing with the shaft B gear are driven by the cage and drive shaft B. Presumably you could add more pairs at right angles if you wanted to transmit more torque. |
Steve Crow | 07/11/2021 11:30:57 |
429 forum posts 268 photos | If I understand it, the two pairs of "contra rotating" pinions are not actually in mesh. Hi Peter, this animation shows the pinions in mesh. **LINK**. Steve |
