sparky mike | 08/10/2021 13:01:45 |
259 forum posts 77 photos | I need to take my Boxford three jaw Taylor (not Clark!! ) chuck to bits as it is getting stiff to opeate. There are two socket head screws in the rear. What do they do ? I have removed jaws. Does the centre push out or screw out to the rear so that the scroll can be removed ? Mike. Edited By sparky mike on 08/10/2021 13:19:01 |
sparky mike | 08/10/2021 16:05:42 |
259 forum posts 77 photos | Panic over. I tapped the chuck gently with a hide mallet, after removing the two sunken screws and the back end of the chuck came off. There is a split dead centre of the chuck key square hole rotators. Cleaned it all out , and there was a lot of bits of brass etc. in various places, but after putting back together it is still a bit on the stiff side. ?? Mike. |
old mart | 08/10/2021 17:12:50 |
4655 forum posts 304 photos | There are two possibilities for the stiffness, there might be some muck in a difficult to detect place, or maybe the chuck is in an unworn condition and the parts are close fitting. You did oil all the moving parts, I trust. |
sparky mike | 08/10/2021 17:50:50 |
259 forum posts 77 photos | It had the remains of grease in it ,which I replaced. It is stiff without the chuck jaws fitted.. There is a thrust washer that sits next to the scroll. I did wonder if that was a fraction too thick, but decided to leave that alone until I gather more info. Mike |
