Emco FB2 clone - how far can you push it?
Diy Addict14/09/2021 14:46:16
34 forum posts
5 photos
I just acquired a used Axminster VHM mill, which is a Taiwanese clone of the Emco FB2. It's a very capable machine for its size - so much so, I'm afraid of wearing it out or breaking it by using too deep cuts etc.
I've been using Sandvik 12mm solid carbide end mills quite a bit for making steel hold-down clamps, tee nuts etc. A speeds & feeds calculator gives a speed of 2500 rpm, so I've been using it at 2000 rpm with reasonable but not great results (I use morse taper collets for toolholding).
So far I haven't risked a cut deeper than 1mm. The motor gets quite hot and I'm also worried about stripping the tufnol gear. So my question is to owners of the FB2 and its clones - how far can you push it milling mild steel without risking damage? What depth of cut would it cope with, for a 12mm (1/2" ) solid carbide cutter, and other sizes? What about DOC for side-milling?
Thanks in advance, Paul
