Alexander Nemeth 1 | 05/08/2021 16:07:29 |
5 forum posts | Hey everyone, I’m getting ready to pull the trigger on a 7x16 lathe and 4.7”x18” vertical mill from little machine shop. I really want to machine a Stuart vertical steam engine and have my eye on the no.4. I already can tell that the 5” flywheel will require a little ingenuity as the swing over saddle on the lathe I want is only 4.3” (OD boring bar maybe?) Anyway, I was wondering if anyone could tell me the height of the standard on the Stuart no. 4 as that is the only part I’m unsure of and want to make sure it’ll fit in the mill for hole drilling operations. if anyone has anything to add on experience with the no.4 on smaller machines, I’d be happy to hear your thoughts and experiences. Cheers, Alurpal
JasonB | 05/08/2021 19:26:55 |
![]() 25215 forum posts 3105 photos 1 articles | The Standard is 4 9/16" tall which should not be too much of a problem if you clamp the feet or flange directly to the mill table. If you do have problems then stub length (screw Machine) drills can be used in a drill chuck or ER collet which is a bit shorter than the average drill chuck. If really pushed then hold in an R8 finger collet with an adaptor if the drill bit is not a stock collet size. A boring bar used upside down and the lathe run in reverse should allow you to turn the flywheel's face. |
Alexander Nemeth 1 | 05/08/2021 21:19:13 |
5 forum posts | Thanks JasonB! Exactly what I wanted to know. Thanks for the video too! Great to see that operation in action. |
