Expanding Foam use
Brian H04/08/2021 17:08:27
2312 forum posts
112 photos
I have a new greenhouse that will be made using thin wall tubes that are pre painted on the outside.
Having had one of these previously, I know that they rot from the inside out. I have an unused can of expanding foam and wondered if this would be suitable to fill the tubes to prevent moisture, or would it be better to use some sort of oil?
Many thanks,
Grindstone Cowboy04/08/2021 17:29:47
1160 forum posts
73 photos
That foam soaks up water like a sponge once the outer skin is damaged. I think you'd be better spraying the insides of the tubes with Dinitrol, Waxoyl or something similar.
Rob
Bob Stevenson04/08/2021 17:34:50
579 forum posts
7 photos
There are expanding foam products specifically for water and moisture environments...presumably they either exclude the water or convert it..... Do some research and you will find these foams. Buy the right one, but they are not cheap to buy.
An amusing story about these foams,..at least it's amusing 'now'! About 20 years back I replaced a bedroom window and bought some foam which I found being sold in a local boot-sale. All went well until I applied the foam after carefully reading the instructions. I applied the foam from the outside but it kept 'growing' outwards around the window and I started to cut it off and drop the pieces into the front garden below. This expansion continued for quite a long time and when I looked down I was shocked to see that I now had a half-garden of foam lumps! Then a thought finally occured to me,...what might be happening on the inside? I slid down the ladder and raced up the stairs,..... a sense of panic and horror filled my chest when I surveyed the enormous toadstools that were well on th way to filling the bedroom! That foam certainly worked!...when things were back under control I had no less than 9 stuffed black sacks, all from just one can of foam!!
I binnded the other three cans and resolved to always do the research be3fore using any unknown products in future!
Rod Renshaw04/08/2021 18:35:26
438 forum posts
+1 for getting the right product. Some foams actually produce water as a waste product as they foam/ expand. This does not matter much in normal use as DIY filler etc, but the water will not readily evaporate from inside a tube and corrosion seems likely. Products made for insertion in car chassis voids, as suggested above seem likely to be more successful.
Rod
