Pete Berry | 26/07/2021 11:59:13 |
![]() 28 forum posts 7 photos | I have recently completed building a CENTAUR ENGINE. It starts and runs well but it does jump about quite a bit.Not sure if the balance would be improved if I used an aluminium piston instead of the cast iron one. I would be interested to hear how other people's engine perform? |
kevin laxon | 26/07/2021 13:04:49 |
19 forum posts | A friend has made several hit & miss open crank barn engine's,we have found the one's that jump about as a rule of thumb don't have the couterweights on the inside of the flywheel rim 180° from the crank pin,some also have the flywheel lightened inline with the crank pin,I know of the centaur but have had no dealings with one,hopefully others will know more. |
MichaelR | 26/07/2021 15:58:43 |
![]() 528 forum posts 79 photos | I built a Centaur and fitted a aluminium piston but not for the purpose of reducing rough running but for my own liking, I don't think a cast iron piston will contribute to rough running. Video of my engine running just sitting on a non slip mat. engine now has a new owner. Edited By MichaelR on 26/07/2021 16:01:56 |
Pete Berry | 26/07/2021 19:16:50 |
![]() 28 forum posts 7 photos | Thanks Kevin I will give it a try. |
Pete Berry | 26/07/2021 19:22:33 |
![]() 28 forum posts 7 photos | Hi Michael your engine certainly runs smoother than mine , I have some ballist in the base but I still have to hold in down. I think I will try an ally piston.
Former Member | 26/07/2021 19:24:37 |
1085 forum posts | [This posting has been removed] |
Pete Berry | 30/07/2021 10:46:21 |
![]() 28 forum posts 7 photos | Problem solved. I balanced the crankshaft as per E Westbury,s instructions in his book "Model petrol engines" I had to increase the size of the balance weight which now have a radius of 3 inches. The engine now runs much smoother without jumping around. |
MichaelR | 30/07/2021 11:08:58 |
![]() 528 forum posts 79 photos | Pleased to hear you have solved your engine problem and with not a great deal of extra work. Michael |
