Solution
martyn nutland | 16/07/2021 17:01:40 |
141 forum posts 10 photos | Hello Everyone I thought those of you who so helpfully contributed to the thread on the dangly probe on my new coaxial indicator might be interested in the denouement. Jason thought, and I had also come to the view, that the reason it didn't work was a lack of resistance between the slot in the beam and the arm that holds the probe. He suggested the simple expedient of devising a way of increasing the pressure on the clamping screw. But of course, by then I had broken the arm! So I milled and drilled a thicker replacement arm to create more friction in the slot. I had difficulty machining the 48° wedge shape (cam?) on either side that bears on the slope of the beam and my version is a lot less elegant than the original. But it does work and is made from good steel instead of some kind of 'monkey metal'. I tested it at 100 rpm on the inside diameter of an Austin Seven piston skirt and got the needle on the indicator dial to quiver around 0.01mm of zero. I don't think I can do much better than that other than send for a Blake! Bonne Weekend Martyn
Howard Lewis | 16/07/2021 17:03:39 |
7227 forum posts 21 photos | Thanks form the feedback. Hopefully, all will now be well! Howard |
Clive Foster | 16/07/2021 17:47:49 |
3630 forum posts 128 photos | Martyn Great to hear that its sorted and giving you good results. That's about as good as I get on any normal object. Need something that has had serious efforts to produce a good finish and accurate roundness to get the twitch significantly less. Never seen absolute rock steady zero twitch but I have seen barely visible movement. They may not be a perfect device but they are darn good by any realistic standards. Most especially so considering the modest price. Clive |
