brian jones 11 | 06/07/2021 17:12:36 |
347 forum posts 62 photos |
now Im sure this must have been done before, so apologies if this is old news. You measure your rim - 36.7mm and make a label divided into 25/25.4 x 36.7 I made my divs 0-1.25, with the black scale counting up towards the work and also counting up red scale away from the work I made the dial resettable as well - another story The reason is that combo slide micrometers are normally used for close finishing cuts. So reset the dial to zero and proceed as desired I checked the dial for 1mm against a dial gauge and it was spot on Of course ther is a small gap between start and finish of the scale but its liveable, its not an absolute dial, its relative I also thought I might make the cross slide with 2x unit scale so that it read diameters instead of radii so 1mm in becomes a 2mm diameter reduction Is that confusing?
apologies for the scale pic is was a trial, I will get a better pic but you get the gist Edited By brian jones 11 on 06/07/2021 17:14:07 |
Pete Rimmer | 07/07/2021 06:50:33 |
1486 forum posts 105 photos | With 10TPI screws you could make your dials dual-reading. 0.1" pitch is 2.54mm so you could print dial scales with 100 divisions for imperial and 250 for metric then the metric scale would only be off by 0.04mm/turn (1.57 thou). Less than the error in a well worn cross slide screw. Some Denford lathes do exactly this. |
brian jones 11 | 07/07/2021 07:01:03 |
347 forum posts 62 photos | Indeed a good point, but i didnt want to post this for being shot down by hardliners who demand precision I will post some pix of labels which can be scaled to suit, or anyone with cad can make their own there are of course cases where a 1.57 thou error is unacceptable eg shaft fitting a bore. if its over it wont fit or else be loose. personally i prefer to know exactly with my fudge but in the agricultural world ................ CNC world works at micron level - scary I am trying out my simple fix for an adjustable micrometer dial (after all a dial gauge has one) but space is very limited and I am trying to keep it simple Any one else been there pls pitch in |
Nigel Graham 2 | 07/07/2021 11:14:02 |
3293 forum posts 112 photos | I would not call it a fudge. The important point is that you know its limits of accuracy (or precision - not a synonym but I can never remember which is which!). |
Georgineer | 07/07/2021 21:38:48 |
652 forum posts 33 photos | Posted by Nigel Graham 2 on 07/07/2021 11:14:02:
... The important point is that you know its limits of accuracy (or precision - not a synonym but I can never remember which is which!). |
Colin Whittaker | 08/07/2021 01:14:52 |
155 forum posts 18 photos | At my old company a nuclear logging expert was giving a presentation in South America to an oil company on the accuracy and precision of a downhole measuring instrument. The prentation employed a simultaneous translation into Spanish but was not well received with lots of bored and/or bemused faces. A post mortem revealed that the simultaneous translator was using the same Spanish expression for both precision and accuracy! |
