Buffer | 28/05/2021 17:23:26 |
430 forum posts 171 photos | Hi Does anyone know what the Sieg SX3 drawbar thread is? I have just measured it with only a rule to count the threads and it seems to be 11mm x 1.25 pitch or 0.431 inch x 20tpi which I assume would be 7/16x20. Thanks
Rob Wheatley | 28/05/2021 17:41:36 |
52 forum posts 28 photos | Think it depends on what collet it is, if it's R8 then it is indeed 7/16 |
John Haine | 28/05/2021 17:41:37 |
5563 forum posts 322 photos | Is this an R8 version? If so I think it's 7/16 unf. Just checked, R8 collet are 7/16 x 20 unf Edited By John Haine on 28/05/2021 17:43:35 |
Peter Cook 6 | 28/05/2021 17:42:16 |
462 forum posts 113 photos | According to the ARC website there are 3 depending on the taper. "Drawbars for the SIEG SX3 mill. Choice of M12 or 3/8” Whit thread for MT3 spindles or 7/16" UNF thread for R8 spindles." |
Bazyle | 28/05/2021 17:42:59 |
![]() 6956 forum posts 229 photos | If, somewhat astonishngly you don't have a vernier caliper or a micrometer you may be able to use the mill table and handwheel graduatons to improvise a measuring system, even make a vernier. |
Buffer | 28/05/2021 18:33:21 |
430 forum posts 171 photos | It's an r8 so the 7/16 then. Thanks for you replies it's all much appreciated. |
old mart | 28/05/2021 18:39:23 |
4655 forum posts 304 photos | Standard for R8 is 7/16 -20 as already mentioned, but I also have one or two R8 tools with metric threads, so I try to check before buying. |
