Emco Compact 5
Robert Bubu | 11/05/2021 12:05:16 |
6 forum posts 2 photos | Hi all, |
Emgee | 11/05/2021 14:03:42 |
2610 forum posts 312 photos | Robert I used the std bearings in my Emco, didn't want the extra clearance of the C3, use the ZZ not the RS, the latter will cause friction on the spindle and heat the bearing, ZZ is sufficient to keep out any swarf that may find it's way into that area. Emgee |
Robert Bubu | 11/05/2021 14:59:07 |
Thanks for the reply "I used the std bearings in my Emco" Standard bearings are- BEARING CLEARANCE - I'm not good at technical data bearings, so I asked which ones are better In the site where I want to buy, there are 2 options: 6006-2Z SKF BEARING CLEARANCE: 2. C3 So, I choose the option 6006-2Z SKF - NORMAL CN ?
Emgee | 11/05/2021 20:14:53 |
2610 forum posts 312 photos | Posted by Robert Bubu on 11/05/2021 14:59:07:
Yes Robert, The SKF 6006-2Z will be fine. Emgee |
