Method to replace battery
Emgee | 01/05/2021 17:38:01 |
2610 forum posts 312 photos |
Has anyone advice on replacing the battery in a Gemini 7208-7218 Alarm key fob, there appears to be a central joint around the perimeter but no access point, perhaps there is a screw under the soft rubber operators ? Emgee
Edited By Emgee on 01/05/2021 17:45:24 |
Grindstone Cowboy | 01/05/2021 18:34:56 |
1160 forum posts 73 photos | Didn't take too long to find this, which seems to have the same remote. Not very explicit on how to separate, so I'd guess at just prising them apart, there's quite often a bit of a gap where the keyring part goes. Links to https://www.gemini-alarm.de/Webshop/contents/de/953_AC2743UK-REV00_U-I_UK.pdf Rob Edit - highly unlikely there is a screw under the button rubbers Edited By Grindstone Cowboy on 01/05/2021 18:35:43 |
Robert Butler | 01/05/2021 21:28:38 |
511 forum posts 6 photos | The Instructions give the impression it slides apart - Arrows! Robert Butler |
Grindstone Cowboy | 01/05/2021 21:43:30 |
1160 forum posts 73 photos | I thought that at first, but I think it's supposed to indicate separation rather than direction. But Emgee could try it and report back. I'm still 80/20 in favour of it simply clipping together. Rob |
Emgee | 02/05/2021 11:36:24 |
2610 forum posts 312 photos | I had downloaded the instruction sheet but no method is stated on how to access the battery, I am sure it doesn't slide apart so will get a Stanley blade and see if can be sprung open as suggested on another forum. Emgee |
