John Roberts 10 | 01/04/2021 19:57:35 |
10 forum posts 1 photos | I recently bought a small Boxford CNC lathe which has been converted to run Mach3 Turn. My problem is the setting of the soft limits within mach. I set the soft limits X soft min -100 mm X soft max 0 Z soft min -130 mm Z soft max 0 I saved the settings. After switching on the home limits i get an error message. Machine out of limits for soft limit activation. This is despite both axis been homed and the work offsets zeroed. (Machine homes in a positive direction as it should) Any advice would be appreciated. John |
Anders Be | 01/04/2021 20:17:49 |
11 forum posts | My guess is that your posistin is outside the limit. I also think soft limits are im machine coordinates. Try to show the machine coordinate at your posision (machine cordinates are always in radius). Best regards Anders B
PS Oh yes, machine coordinates are unaffected by work offset. DS Edited By Anders Be on 01/04/2021 20:23:25 |
John Haine | 02/04/2021 10:08:32 |
5563 forum posts 322 photos | Hi John, Homing and soft limits can be a bit of a minefield. My approach is as follows - hopefully there may be something here to help with your problem. Note the numbers here are for my Super 7, yours would probably be less for a smaller lathe.
All this is done in machine coordinates. When I select programme coordinates and a tool then the X DRO shows the actual turning diameter provided the tool offsets are set up. Work offsets and tool offsets do not affect machine coordinates. For one-off work, work offsets are irrelevant I think. The above procedure allows me to turn to a diameter relatively accurately without having to touch off the tool to the material. For the Z axis I have a tool touch sensor and a macro that will find the end of the material in the chuck, zero the X pgm coord, and move the tool 20mm to the right. I hope this helps, ask away if anything not clear. |
John Roberts 10 | 02/04/2021 19:46:36 |
10 forum posts 1 photos | Thanks for your replies. It appears that soft limits only work in Mach turn when radius mode is set. There is no reference to this in the manual. I found a commit on the mach3 forum to that effect. When I tried it in radius mode it worked. I wish to stay in Dia mode so will have to do without soft limits on my lathe. John |
Martin Connelly | 03/04/2021 08:21:58 |
![]() 2549 forum posts 235 photos | I use a clamp on limit switch for negative Z axis moves. The option of using collets or a chuck makes a fixed one problematic as mentioned by John. I use this for homing/limits once the setup is done so that any error or overnight shutdown can be recovered from with minimal effort. You could easily mount fixed ones on the X axis and moveable ones on the z axis and then not worry about soft limits, just need to remember to set them up after things like chuck changes. Martin C |
John Haine | 03/04/2021 10:21:37 |
5563 forum posts 322 photos | Posted by John Roberts 10 on 02/04/2021 19:46:36:
Thanks for your replies. It appears that soft limits only work in Mach turn when radius mode is set. There is no reference to this in the manual. I found a commit on the mach3 forum to that effect. When I tried it in radius mode it worked. I wish to stay in Dia mode so will have to do without soft limits on my lathe. John Well I just checked on my lathe which is in diameter mode and soft limits work on both X and z axes exactly as expected. This may be version dependent, I am using R3.043.062 which I believe is the latest recommended for Turn as it supports threading correctly. Edited By John Haine on 03/04/2021 10:22:33 |
John Haine | 03/04/2021 13:20:45 |
5563 forum posts 322 photos | |
John Haine | 04/04/2021 08:31:15 |
5563 forum posts 322 photos | And looking again at your first post, note that your zero home position is at a soft limit. You need to make sure that the soft limit range brackets the machine coordinate zeros. |
