prazi SD300 spindle removal question
Henry Rancourt13/03/2021 20:18:45
20 forum posts
47 photos
The manual shows two snap rings that rest against shim washers that rest against the inner bearing faces. Based on that it seems that the rear bearing must be a sliding fit on the spindle so it can be removed before tapping the spindle out towards the tailstock. Is that a valid assessment?
DiogenesII13/03/2021 21:43:37
859 forum posts
268 photos
It is - this chap (to whom I have no connection) posted a record of removal / replacement for posterity here;
Bazmonaut MD65 Spindle Bearing Replacement
Henry Rancourt14/03/2021 01:08:31
20 forum posts
47 photos
I had read the bazmonaut spindle replacement but missed the sliding bearing bit.
Roger B14/03/2021 08:06:02
244 forum posts
105 photos
The rear bearing is a sliding fit on the shaft so that the end play can be adjusted with the two nuts. There is no need to remove the rear bearing before taping/pulling the spindle out.
Why do you feel that you need to replace the bearings?
