Dave Owen 1 | 10/02/2021 23:03:50 |
2 forum posts | Hi Guys i was looking at replacing speed control on my mashtroy ( warco 220) lathe with a VFD, any one done so and if so how did you go about it? Regards Dave |
John Olsen | 11/02/2021 02:59:51 |
1294 forum posts 108 photos 1 articles | Depends what the existing motor is. Apparently the earlier ones came with single phase while the later ones came with a variable speed motor, I don't know what sort, but quite likely some sort of DC motor or a universal type of AC motor. To use a VFD you would need a three phase motor, so it very probably would require you to buy both the motor and the VFD. So unless the existing motor is a three phase one, it would be quite an expensive exercise, although still probably worthwhile. John |
old mart | 11/02/2021 17:27:47 |
4655 forum posts 304 photos | As mentioned, the motor would require changing for a 3 phase one, and you would have to do some careful measuring to find out whether there is room to fit one. |
