Erik Shepherd | 16/01/2021 22:08:08 |
3 forum posts 1 photos | Good evening chaps.
My first post here, although I've been an active browser for some time now, so apologies if it's in the wrong place.
I've recently bought a Chester 920 lathe from someone, who clearly never used. Bargain, I reckon. Anyway, it has clearly been neglected as the leadscrew was disconnected, the thread cutting lever was completely jammed up and some other things not quite the way I would like them. Oh - and it was missing the 127 tooth gear, which after several evenings of googling turns out to be unobtainium, so I 3D printed my own and it's been running brilliantly.(if anyone is in a similar predicament as me, drop me a message. Happy to help)
Anyway, onto my question - The lathe runs great, but it has a rather alarming issue - when starting the motor, it makes quite a horrible noise. Sounds a bit like gears mashing together, but it comes from the motor itself. Also, it seems to bog down quite easily when taking deep cuts and on few occasions has even stalled, resulting in a horrid noise that made my cats jump. I was wondering if anyone had similar experiences and recommendations for the best way to remedy this. Currently I'm making the 4 bolt cross slide clamp as the factory one is far too loose and wobbly for my liking(I've used Colchester lathes at uni, so I'm aware that this won't be anywhere near the power or rigidity of what I'm used to, but a 0.1mm facing cut really shouldn't be a problem...)
Thanks in advance. Erik |
Niels Abildgaard | 17/01/2021 08:06:49 |
470 forum posts 177 photos | Throw old AC motor out and put a sewing machine motor on. I did and it sounded very nice and was easy to alter speed. |
Howard Lewis | 17/01/2021 10:34:19 |
7227 forum posts 21 photos | Sounds like someone had ABused the machine! Does the motor make strange sounds when starting, without the belt? Is the pulley tight on the motor shaft, rather than slipping? Is the belt a toothed one? If YES, Could it be slipping? Are the motor bearings worn? If you can eliminate each possible cause of the noise, you will eventually find the cause and be able to do something to cure it. Howard |
Pete. | 17/01/2021 12:56:00 |
![]() 910 forum posts 303 photos | I've got an early Taiwanese 9x20, not sure if they're exactly the same, I had a noise coming from that area that was remedied by tightening the cap head screw in the centre of the pulleys, might be worth checking. |
Erik Shepherd | 17/01/2021 22:30:58 |
3 forum posts 1 photos | Thanks for all the advice everyone. Greatly appreciated.
Got to the root of the problem - it wasn't the motor at all, but instead the belt that connects the pulley to the geartrain was criminally loose!
Cheers |
Howard Lewis | 18/01/2021 18:34:10 |
7227 forum posts 21 photos | Thanks for letting us know. Glad that it was a simple problem with zero cost / trouble solution. You may have made life and sleep easier for someone else who has similar problems. Howard |
Ron Laden | 18/01/2021 20:19:16 |
![]() 2320 forum posts 452 photos | Posted by Erik Shepherd on 17/01/2021 22:30:58:
Cheers Good you found the problem Erik but a correctly adjusted toothed belt shouldnt be like you say "as tight as a drum" it needs easing back a touch. If you take the flat of the belt between your thumb and forefinger you should just be able to twist the belt through 90 degrees that should be about correct for a belt of that size. Ron. |
