Simon Robinson 4 | 13/01/2021 22:00:14 |
102 forum posts | Hi Im thinking of building a 1:72 Boeing 747SP cutaway model. The problem is that’s 185 seats. Is there an easy way to make so many seats? |
Nigel Graham 2 | 13/01/2021 22:16:11 |
3293 forum posts 112 photos | Do you have access to a 3D printer? That would seem one route. Alternatively, are their shapes amenable to being pressings within range of some die-making and a fly- or arbor- press? |
Peter Seymour-Howell | 13/01/2021 22:17:03 |
![]() 125 forum posts 25 photos | Hi
If I was building that I would make patterns of the various seat styles and setups, mould them in silicone and then cast in resin. You'll find all you need from Terranti's, supplier of the materials required.
Pete |
The Novice Engineer | 13/01/2021 22:49:14 |
85 forum posts 72 photos | Hi It depends on how deep your pockets are and how open you are to new technologies ! My suggestion would be to use 3D SLA printing With SLA printing it takes the same time to print a plate of lots of items as a single item. I have had some good results using an Anycubic Photon , not as expensive as some models to buy [£100's rather than £1000's] Steve Edited By The Novice Engineer on 13/01/2021 22:52:25 Edited By The Novice Engineer on 13/01/2021 22:59:12 |
ega | 14/01/2021 14:21:58 |
2805 forum posts 219 photos | In former times such items could have been made by machining a strip of wood or other suitable material to a cross section to match the profile of the item; they would then be cut off to length and finished. The animals in "Noah's Arks" were made in a similar way, the blank sometimes being turned to section in the lathe. |
norman valentine | 14/01/2021 14:52:46 |
280 forum posts 40 photos | Are the shapes suitable for vacuum forming? |
