KEITH BEAUMONT | 11/12/2020 16:00:00 |
213 forum posts 54 photos |
The Crankcase as drawn has a radial mounting, This has been changed to a beam mount I have lengthened the crankshaft to allow a spinner in place of the plain nut. Added a bronze bearing to the front housing that also has a single ball race. Also changed to a split collet for the prop driver in place of the fixed taper.. The Fins and Cylinder were held down by four long screws,but I have put a thread on the Cylinder to allow the fins to be screwed down. Cylinder height was increased by 0.375"as the Contra piston,as drawn is too shallow for the method I use to make them. I put about 0.005" taper to the outside,with a thin wall of about 0.020",.Diameter is then turned with a good finish to allow it to enter the cylinder for half its length. This will then push into the cylinder giving a gas tight fit with the Screw fitting.For the last three engines I have made this from EN1A,rather than C/.I . I smear copper loaded grease on it on assembly to avoid any chance of seize. Cosmetically I have tried to soften the appearance. The Fins , Prop Driver and Spinner are anodised and the crankcase has been bead blasted to give an overall smooth mat finish. To add to the "bling" I added blue S/S mush head screws. It has proved to be an easy starter and to date it has had five runs of about two minutes each, running rich ,with a 10"x 4" nylon prop, RPM at this stage is around the 8000 mark. I have several props of other size to use on later runs. Putting potos on here is a nightmare! Why do they end up in the reverse order that I click on them? I would expect to start at the top of the list, not the bottom. Keith |
Roderick Jenkins | 11/12/2020 16:13:54 |
![]() 2376 forum posts 800 photos | Another nice one Keith. Well done! Stay well, Rod |
KEITH BEAUMONT | 11/12/2020 16:21:54 |
213 forum posts 54 photos | Thanks Rod, Always good to hear from you. Keith |
Jeff Dayman | 11/12/2020 17:18:11 |
2356 forum posts 47 photos | Great engine Keith! well done. |
KEITH BEAUMONT | 11/12/2020 20:58:55 |
213 forum posts 54 photos | Thank you Jeff. It is always good to hear from across the pond. Keith |
Ramon Wilson | 11/12/2020 21:09:31 |
![]() 1655 forum posts 617 photos | Another very nice looking home built engine Keith Love the blue anodising - what did you use? 5cc next perhaps?
Regards - Tug |
KEITH BEAUMONT | 12/12/2020 12:44:47 |
213 forum posts 54 photos | Thanks Ramon for you comments The engine is quite noisy with a real crackle to the engine note,which is always music to my ears. I take the easy way out with anodising and have it done with a "sympathetic" local firm.. I have sent you a message in your box. Keith
Ramon Wilson | 12/12/2020 15:13:19 |
![]() 1655 forum posts 617 photos | You can't beat a good 'crackle' Keith - that and the aroma Lucky you on the anodising - my local was just the opposite! PM received and sent Regards -Tug |
