Compton Series 2000 starter
Peter Howell 103/12/2020 11:58:58
44 forum posts
4 photos
My Myford Super 7 has a Compton Series 2000 starter.
Occasionally it doesn't switch on. The contactor jumps but doesn't lock on. If I manually press in the contactor block in (with an insulated screwdriver) it works. Then the starter will work normally for several stop/starts.
Is there something I can do or will I have to replace the whole unit?
john fletcher 103/12/2020 12:27:26
893 forum posts
No need of a new starter. I'm not familiar with a Crompton 2000, but most probably the latching /auxiliary contacts are in need of a careful clean. Disconnect the electric supply, remove the starter cover and using a torch you will see the contacts, insert a piece of paper between the contacts, carefully push the contacts closed, then pull out the paper. that usually does the trick. Also, have a look at the over load contacts, as they are in series with the latching ones. and they might be in need of the treatment. . John
Peter Howell 103/12/2020 14:42:06
44 forum posts
4 photos
Thanks John, unfortunately I've just looked and the Crompton appears to be completely sealed. There are no contacts visible. I would have to dismantle the assembly to get to them. The same applies to the overload unit.
