Willson 7.5" lathe. New owner
Willson lathe
Matthew Morgan22/11/2020 19:47:42
3 forum posts
Good evening
I have recently acquired a willson 7.5" lathe.From what I have been told its an earlier version with the 90 degree gear lever handles.
I am trying to find out more regarding the spindle fitting to the chuck backplate. The book for the lathe mentions 6tpi but no more. And i have managed to get the current 3 jaw and backplate off and the spindle measures 3.5 inches across. Would anyone here Know the thread type or even point me in the direction for another backplate or a 4 jaw chuck with a backplate, I'd also like to find a faceplate and a fixed steady.
I'm fairly novice to the lathe world so go easy on me
Many thanks
Matt
Dave Halford22/11/2020 20:23:00
2536 forum posts
24 photos
try this link
ega22/11/2020 21:19:18
2805 forum posts
219 photos
It will almost certainly be a Whitworth form thread (I assume your machine has a traditional screwed spindle).
Later lathes had American "L" type long taper spindles which may have specified a 60 degree thread; I will check my own, smaller, Willson slant bed when I next remove the chuck.
Quite a lathe for a novice - I wish you good luck with it!
Matthew Morgan22/11/2020 22:22:19
3 forum posts
Ega
Yes it has a traditional screw spindle. Info on them says about later ones being L type. I'd imagine yours would be a L type?
ega22/11/2020 23:15:21
2805 forum posts
219 photos
Posted by Matthew Morgan on 22/11/2020 22:22:19:
Ega
Correct - an L0.
ega23/11/2020 10:14:01
2805 forum posts
219 photos
This Willson test certificate may be of general interest (I do not now know which model it relates to):
old mart23/11/2020 19:14:10
4655 forum posts
304 photos
If the lathe uses a L0 fitting spindle, then the backplates are available new. Second hand ones come up on ebay frequently as well.
Matthew Morgan23/11/2020 19:56:05
3 forum posts
Old mart
Unfortunately it's not a L series. It's an older thread on type
old mart24/11/2020 15:35:34
4655 forum posts
304 photos
Thats a shame, a drawing of the spindle end would be helpful. There is a possibility that more than one type of chuck could share the same backplate, so the dimensions of the front of the plate would also be useful.
