John Hall 7 | 09/10/2020 19:11:37 |
90 forum posts 2 photos | Hi, has anyone dismantled a Baty dial indicator? i want to remove the front glass and bezel to clean the face...There is a small hole in the bezel and when turned, 4 small slotted screws are revealed. Do these need to be removed to allow the glass and bezel to come off? cheers John |
gerry madden | 09/10/2020 19:55:09 |
331 forum posts 156 photos | Just so happens John I did one last week. If I remember mine only had three screws and I could get away with removing two for dismantling. However when in came to reassembly I took out the third one too as as it made it easier to get the dial and everything else in the right place with an even compression. G. |
John Hall 7 | 09/10/2020 21:09:14 |
90 forum posts 2 photos | Thanks zGerry...much appreciated.. |
