What is this?
Identify mystery Myford Accessory
Andrew Phillips 405/10/2020 11:07:51
30 forum posts
Hi All,
I bought my Myford Super 7 some years ago, and it came with a number of accessories, including this object. Painted in Myford grey, it has a pointer(?) moved in an out (in a straight line) by the knurled screw, which is threaded internally and externally. See pictures. Any ideas what I have here? Thanks, Andy
Tomfilery05/10/2020 11:53:01
144 forum posts
4 photos
Andrew,
Would it wedge into the top of the pulley housing (once the belt cover is open), allowing the pointer to be engaged with the bull wheel gear for basic indexing?
Regards Tom
not done it yet05/10/2020 12:18:00
7517 forum posts
20 photos
Andrew,
Looks like Tom may well be right. If it is, please can you supply approximate/rough - even accurate - drawings so that others can knock one up. I’m sure some of the myford users would appreciate that.
Andrew Phillips 408/10/2020 20:48:21
30 forum posts
Hi, thanks for your input. I tried the device afainst my Super 7 (see pics) and there is no obvious way it can be mounted to act as a detent on the bull wheel, the most likely place it could be used for basic indexing. Furthermore, the tip is too large to engage in teh teeth of a 60-tooth gear (see pic). Any other thoughts gratefully received, Andy
Nicholas Farr09/10/2020 07:41:57
3988 forum posts
1799 photos
Hi Andrew, do the two lugs sit between the ways snugly? If so maybe it's for off setting or resetting the tailstock centre for taper turning.
Regards Nick.
Bazyle09/10/2020 08:32:33
6956 forum posts
229 photos
Grey is a pretty universal colour for machines. More likely off a tool and cutter grinder.
