Warco Major Mill
Derek cottiss28/09/2020 17:30:46
36 forum posts
im about to take possetion of a major mill drill s/h
would like to add power feed and a dro any suggestions what to look for and from who ?
thank you
Nicholas Farr28/09/2020 18:02:49
3988 forum posts
1799 photos
Hi Derek, you can get a power feed at power feed Warco. Just scroll through the accessories
Regards Nick.
Edited By Nicholas Farr on 28/09/2020 18:05:31
Derek cottiss28/09/2020 18:08:30
36 forum posts
Posted by Nicholas Farr on 28/09/2020 18:02:49:
Regards Nick.
saw that just wondered if there were better /cheaper optioms as if i buy it all from Waco its more than the mill ...
Howard Lewis28/09/2020 18:11:41
7227 forum posts
21 photos
Have not got power feed because, from memory, are only supplied in 110 Volt form and the unit and the 240 / 110 volt transformer are quite a costly combination.
John Rudd28/09/2020 18:21:43
1479 forum posts
Go to your friendly local electrical wholesaler and buy a 240/110 control transformer rated at 200VA.....
if you can wire a 13A plug, you can wire up the transformer easy enough....
I paid around £30 for mine then another £20 for a suitable enclosure....still cheaper than buying from 'tool merchants'
No doubt other members will share their pearls of wisdom...
Nicholas Farr28/09/2020 18:27:14
3988 forum posts
1799 photos
Hi Derek, sorry I don't know anything else that may be suitable, may be worth looking around second hand places.
Regards Nick.
Packmule28/09/2020 19:35:46
133 forum posts
6 photos
Hi Derek,
just about to undertake this project. Bought parts form that well known auction site total cost around £70
I know someone has has built this and he's very pleased with the result.
Hope it helps,
Bob
Power feed
Derek cottiss28/09/2020 21:20:50
36 forum posts
Posted by John Rudd on 28/09/2020 18:21:43:
what did you use as the motor ?
John Rudd28/09/2020 21:31:05
1479 forum posts
I bought a proprietry unit that bolted to the mill table, as it was a 110v unit, it need a 110v supply, hence the cheaper route of buying a control transformer rather than a 'proprietry' unit as supplied by the 'tool merchants'...
Packmule28/09/2020 23:26:39
133 forum posts
6 photos
I bought a 12v 600rpm motor.
