Machining smokebox door.
Bob Lamb26/09/2020 19:06:35
140 forum posts
51 photos
I have a smokebox door with hinges cast onto the front. Is there a cunning way of cleaning the front up and maintaining the hinges? Is it actually much easier to cut them off, turn the front of the door and then make and rivet on new hinges? Thanks in advance for any suggestions. Bob
Baz26/09/2020 19:54:34
1033 forum posts
The only cunning way I have found is a selection of files, most probably easier to cut them off, turn the door and make some and rivet on.
Paul Lousick26/09/2020 23:32:47
2276 forum posts
801 photos
Not knowing the size or details of the door we can only guess (a photo, drawing, dimensions would help).
Filing as suggested, milling m/c with door on a rotary table, or possibly an angle grinder (or Dremel) using sandpaper type flap wheels and discs, etc.
Paul.,
Paul Lousick27/09/2020 01:45:42
2276 forum posts
801 photos
One of my favourite tools for finishing odd shaped parts is a power file. Mine is a Black and Decker which I have had for years but lots of others available at the local hardware store.
Paul
Edited By Paul Lousick on 27/09/2020 01:46:13
Bob Lamb27/09/2020 07:49:13
140 forum posts
51 photos
Baz - I tried small files and emery paper and came to the same conclusion as you - cut them off and start again.
Paul - It's a 3 ½" Maisie, so not very big. I have tried the Dremel which worked quite well but is difficult to get an even finish round the hinges. I don't have a rotary table. I had not thought of a power file - could be the opportunity to justify buying one! I have often thought it might be useful to have one so maybe now is the time.
The other problem of leaving the hinges on is getting the outside edge circular. I tried holding it by the chucking piece and turning the lathe by hand with very small cuts so that I could stop when it reached the hinges, I thought I would then be able to finish the bit between the hinges by hand. This works ok but I think I will probably end up cutting them off and putting on new hinges.
Thanks for the suggestions - Bob.
