Paint and painting specialists question
gerry madden24/08/2020 20:18:25
331 forum posts
156 photos
I have an umpteen tin of Fosroc Galvafroid paint that's in good condition so Im using it on some castings in the unseen areas. All is fine except for cleaning the brush afterwards. The tin says 'use Fosroc thinners'. Ive tried white sprit, turps and modern Hammerite thinners. The latter has no effect. The turps and white sprit don't really dissolve the paint, instead they turn it into rubbery lumps which have to be brushed out of the brush.
Does any one know what might be a proper solvent for this paint or an equivalent to the Fosroc thinner ?
My castings have been bead-blasted so all the old surface filler has been removed. I now have to refill and smoothen them. What would be a good filler for this job please ?
John Rutzen24/08/2020 20:23:01
411 forum posts
22 photos
Hi, use what is called Standard Thinners which you can ge tin a 5 litre for less than £20 usually from motor factors or even on Amazon. It is good for cleaning out spray guns or brushes that have been used for any kind of paint that is not oil or water based.
Clive Foster24/08/2020 21:36:35
3630 forum posts
128 photos
Quick Google shows the official thinners to be available at around £40 for 500 ml. Yikes!
The safety data sheet gives the active ingredient as Solvent Naphtha. **LINK**
Allegedly Lighter Fluid is pure naphtha. Still around for Zippo enthusiasts I see. Naphtha seems to be around at around £5 a litre but no indications as to how pure it is
Not sure that ordinary gun cleaner will do it properly.
Nicholas Farr24/08/2020 21:50:20
3988 forum posts
1799 photos
Hi, probably cheaper to just buy new brushes or put the handle through a hole in the lid and seal it and store the brush in the paint.wink 2
Regards Nick.
Steviegtr24/08/2020 23:44:45
2668 forum posts
352 photos
If standard cellulose thinners does not work try some Acetone, (nail varnish remover),
. I use it a lot when doing glass fibre work.
Steve.
Peter Low 425/08/2020 07:45:07
24 forum posts
7 photos
In use Galvafroid and standard thinners does the job.
Clive Foster25/08/2020 08:56:39
3630 forum posts
128 photos
Peter
For completeness does standard thinners also work as a thinners when applying the Galvafroid or is it only suitable as an equipment cleaner.
Years ago I got into terrible trouble when I used standard thinners with one of the more exotic paints thinking that if it would wash the brushes out it would do fine to thin it down for spraying. Took weeks to dry enough t get the mess off any sense. I doubt if it would every have dried properly.
gerry madden25/08/2020 16:24:24
331 forum posts
156 photos
Thanks for all your efforts and advice chaps. I have some acetone on order for other things so will try that. If not I'll probably use new brushes as I appear to have accumulated quite a few in my brush box.
No one commented on the filler for the casting surface. I'll try something from Halfrauds if the popular products are ok to use directly on bead-blasted iron surfaces.
Gerry
Steviegtr25/08/2020 20:02:05
2668 forum posts
352 photos
I would have thought that car body filler would be ok. Or hi build primer.
Steve.
