John Rutzen | 21/07/2020 08:23:58 |
411 forum posts 22 photos | Hi, Does anyone have experience please of adding an optical encoder to a vertical mill [this one is an Amadeal] and driving a stepper motor with suitable software and circuitry so as to build a gear hobber. There is a Youtube video on doing this but it is 2010 so I am sure the software would now be out of date and the optical encoder which he built also. Thanks. |
DC31k | 21/07/2020 08:38:06 |
1186 forum posts 11 photos | Put 'stevenson gear hobber' into Google. Read and digest everything you find (including the back issues of MEW). Then you will be in a better position to understand the state of the art and crucially the boundaries/limitations of the method. It is this understanding, more than anything else, that will determine the success or failure of your venture. Look at the electronic leadscrew thread here and on YT. Same basic principle of electronic gears rather than mechanical gears. Software and encoders are 'industrial Lego' and are easily replaced. |
John Rutzen | 21/07/2020 11:02:12 |
411 forum posts 22 photos | Thank you I'll look that up.
John Rutzen | 21/07/2020 11:16:14 |
411 forum posts 22 photos | Please could you tell me which back issues of MEW are relevant. Thank you. |
Jimmeh | 21/07/2020 12:38:50 |
![]() 27 forum posts 12 photos | Afternoon John. You can find the electronic leadscrew thread here: Clough42 ELS Project on YouTube Cheers, James |
DC31k | 21/07/2020 14:35:57 |
1186 forum posts 11 photos | https://www.model-engineer.co.uk/forums/postings.asp?th=75580 |
Another JohnS | 21/07/2020 15:14:59 |
842 forum posts 56 photos | John; If you are referring to Andy Pugh's hobbing videos; it is still very relevant and in use all the time. It's LinuxCNC, which is the base for the Tormach controls now. You can contact him via the LinuxCNC.org forum, or the mailing list, he seems to be very helpful. It seems like any optical encoder can interface so long as it has the index pulse will work with LinuxCNC for this purpose. It's a cost-effective solution, but one that is not off the shelf. John. |
John Rutzen | 21/07/2020 15:25:44 |
411 forum posts 22 photos | Yes it was the Andy Pugh one I watched. I will try to contact him. Thank you. |
John Rutzen | 23/07/2020 11:45:39 |
411 forum posts 22 photos | Hi, I've not been able to get in touch with Andy Pugh. I couldn't see how to contact him on the linux forum. I've been looking at my Amadeal mill and of course it already has a sensor on the spindle that feeds the rpm back to the control board. Has anyone investigated what this output is and whether it could be used to input to a arduino? |
Another JohnS | 23/07/2020 12:25:30 |
842 forum posts 56 photos | John; First, check your messages for Andy Pugh info. If your mill ls like my "King Canada KC20" (sold under different names) then yes, you can send the signal to a computer; it won't give you rotation direction nor does it have an index pulse, but it's great for ensuring that the mill is running at the correct speed, no matter what gear you are in.
Bazyle | 23/07/2020 13:41:08 |
![]() 6956 forum posts 229 photos | I assume this is the video mentioned Are the teeth on a hob of this type straight sided like a rack style hobber? Is there a correction to the pressure angle on the hob? |
John Rutzen | 23/07/2020 13:43:14 |
411 forum posts 22 photos | Thank you John, got the message. My mill is an Amadeal with the brushless dc motor so I expect it's the same. It's out of warranty so i thought of putting a connector on the side of the control box and taking the output. I wish I had an oscilloscope so I could check what the output is.
John P | 23/07/2020 14:23:07 |
451 forum posts 268 photos |
In reply to your opening post. I have an optical encoder fitted on the quill of my Warco mill when it is set (Would it be a good idea to turn up a steel ring and loctite it in place?) The photo here shows the encoder clamped around the column and gear |
John Rutzen | 23/07/2020 21:10:29 |
411 forum posts 22 photos | Bazyle- it was the Andy pugh video I knew about, I haven't seen the one you gave me a link to. John- how many pulses per rev does your encoder give? I am trying to do this with arduino but i would like to know how much the system costs for one already made please. |
John P | 24/07/2020 18:38:50 |
The photo here shows the encoder on the mounting plate, |
John Rutzen | 24/07/2020 22:19:43 |
411 forum posts 22 photos | Thank you for the information John. Looking at your milling machine it is obviously much larger and more powerful than mine is. The problem I would have with the standard 2 - 2.5 inch diameter hobs is that I don't have slow enough speeds. Mine does not have back gear and the torque just isn't enough at slow speeds. I think ArcEuro used to do small hobs but i can't find them on the site now. |
John Rutzen | 24/07/2020 23:00:06 |
411 forum posts 22 photos | I might fit back gear of course and use the bull wheel to drive the encoder. I had thought of fitting back gear , it wouldn't be too difficult. |
John P | 25/07/2020 13:59:53 |
451 forum posts 268 photos | Hi John The Warco machine that i have is an A2F ,Warco no longer sell these, I don't hob gears above 1.25 mod / 20dp as i find most of the stuff |
John Haine | 25/07/2020 14:27:27 |
5563 forum posts 322 photos | Just a quick note that an alternative to a high count encoder on the spindle is a phase-locked loop IC with even a 1 pprev encoder to multiply up the frequency - the CD4046 type chip should do the job. Also I think Joe Noci has built a processor-based system that does something similar in software. |
John Rutzen | 25/07/2020 18:01:13 |
411 forum posts 22 photos | Thanks for all the input. I don't know really how to get over the slower speed problem. I see from my book by ivan Law that he used a Dore Westbury mill which I believe had an epicyclic gearbox inside the pulley. I don't think I could fit one to mine since the pulley is far too small. Hobs on eBay all seem to me around 50 -55 die. |
