Step chuck modification
Plasma06/07/2020 07:47:14
443 forum posts
Hi all.
I've had a smart and brown model L headstock laying about for a long time, with half a plan to use the step chuck on my Boxford lathe.
I finally got round to modifying a mounting plate for it, which is a D-1 3 mount.
I had to cut off the end of the hardened steel spindle to use and machine a backplate to suit. I didn't fancy my chances at making a backplate with suitable spindle nose thread. Plus it will only see occasional light use so I didn't need to make something so involved.
It was a relatively straight forward job but cutting the spindle was the hardest part, I used a disc grinder with the spindle rotating slowly in a very well covered lathe.
I can now use my s&b collects and the step chuck On either of my Boxford lathes for thin piece work etc.
Phil P06/07/2020 09:12:33
851 forum posts
206 photos
It is nice when all your work holding gear fits multiple machines.
I also try and use the same collets etc, on my dividing heads and rotary tables.
Phil
Martin Connelly06/07/2020 09:37:39
2549 forum posts
235 photos
Did you have to make a draw bar or draw tube to go with the collets or is there something else closing the collets?
I have a step chuck and a cone chuck. They are rarely used because they usually don't fit what I have to hold. I think there were 3 sizes in a set of each and I only have one of each. I find soft jaws in a 3 jaw chuck more useful.
Martin C
old mart06/07/2020 21:20:36
4655 forum posts
304 photos
I have bought several of both types of step collets for the museum's model A, including one from this firm, they had two, but they were both the same size.
Plasma06/07/2020 22:19:03
443 forum posts
I have a set of four step collects, each with different ranges. I will post the sizes tomorrow, they pretty much cover a fair range of sizes.
I had the draw bar tube for the original lathe but it was a shade too short. So I made a small extension piece and fitted a spare handwheel so that it fits.
I'm quite happy with it for thin piece work, I don't have any soft jaws so this will be just the job.
