Aluminium on Brass Wheels
Aluminium deposit on brass wheels
Patrick Rundle 122/06/2020 16:12:01
2 forum posts
I have been plagued with a problem for some time and unable to find a solution.
I have cut some brass wheels using an aluminium backing disk. On some of the wheels aluminium is transferred onto the brass during the cutting process.
I have yet to find a way of dissolving aluminium and not the brass - the best so far is Drain Cleaner which bubbles for some time, doesn't seem to attack the brass, but does not remove all the aluminium.
Can anyone suggest a solution for this problem?
Thanks
Pat
Andrew Tinsley22/06/2020 16:24:58
1817 forum posts
An easy solution is to dunk the wheel in an alkali solution. Sodium hydroxide solution is probably the best , but any alkali will do. Sodium carbonate solution (washing soda) or sodium bicarbonate solution should do the job, but more slowly.
Andrew.
Patrick Rundle 122/06/2020 16:38:35
2 forum posts
Thanks for that.
I've checked the contents of the HG liquid drain unblocker I used and the active ingredient is sodium hydroxide.
As I said it bubbles for some time so is probably dissolving most of the aluminium.
The surface left when bubbling stops still looks aluminium coloured rather than brass coloured.
Pat
