Help finding parts for a Drummond lathe..
Richard Senior | 13/05/2020 19:53:33 |
5 forum posts 2 photos | Hello,
Anyway.. onto the matter at hand. It's a Drummond 3.5" flatbed circa 1904/1906 The headstock bearing really needs replacing...
Thank you Richard |
Oldiron | 13/05/2020 20:04:52 |
1193 forum posts 59 photos | Hi Richard welcome to the forum. Have a look at lathes.co.uk you may find some useful information there. I am sure a Drummond owner will be along soon and give you some help. regards |
Richard Senior | 13/05/2020 20:12:42 |
5 forum posts 2 photos | Thank you. |
Keith Long | 13/05/2020 20:18:25 |
883 forum posts 11 photos | Hi Richard, yes I'm a Drummond lathe owner (several) but none of that model I'm afraid. Have you joined the io groups Drummond group yet https://groups.io/g/drummondlathe lots of helpful folk on there and often you find someone has the bit that you need. There were at lease a couple of versions of the headstock bearings for that model but I'm pretty sure they were all solid bronze bushes pulled into tapered housings, but the means of pulling changed during the run of that model. If the lathe isn't totally worn out you should be able to make the new bushes from bronze stock on the machine itself, you'll just need the dimensions. Someone on the Drummond group can probably tell you that straight off.
Richard Senior | 13/05/2020 20:24:51 |
5 forum posts 2 photos | Keith, |
Richard Senior | 13/05/2020 20:24:52 |
