old mart | 25/04/2020 15:45:42 |
4655 forum posts 304 photos |
Here are some pics:
Howard Lewis | 25/04/2020 15:47:46 |
7227 forum posts 21 photos | Biased, but my choice would be as a rear toolpost. Howard |
old mart | 25/04/2020 20:56:16 |
4655 forum posts 304 photos | Does anybody know which lathe it is from? |
old mart | 25/04/2020 20:56:17 |
SillyOldDuffer | 26/04/2020 18:55:24 |
10668 forum posts 2415 photos | Posted by old mart on 25/04/2020 15:45:42: ... ... The eight clamping bolts are 3/8" 16tpi, with 3/8" square tops. The four threads in the base are a bit of a mystery, too big for 1/4" and not big enough for 5/16", the only thread left would be 7mm which is rather rare. ...
Could they be 9/32nd BSF? (A little over 7mm, but imperial like the others.) Dave |
old mart | 27/04/2020 16:03:48 |
4655 forum posts 304 photos | I have solved one part of the puzzle, the threads underneath are 5/16 UNC. I made an impression of the threads and found the pitch to be approximately 16 to 18 tpi. That definitely narrows it down to BSW or UNC. I had tried what was probably a BSW bolt without it screwing in, but today I had another search of the garage and found a bolt with the nuts on it. The nuts were too small for BSW so it is probably UNC. It is a tight fit, but screws right to the bottom of the hole. Not being able to get to the workshop at the museum because of lockdown is a handicap. I still will need to strip it down before deciding what to do with it, the rear toolpost for larger boring bars is current favourite, it will be much stiffer than any standard one can be, and 25mm left hand bars will fit it. I will be asking about this toolpost on the Home Shop Machinist to increase the chances of somebody recognising it. |
old mart | 28/04/2020 20:22:40 |
4655 forum posts 304 photos | If anybody is interested, I have succeeded in getting the toolpost to bits, pictures of its guts here:
Michael Gilligan | 28/04/2020 20:36:16 |
![]() 23121 forum posts 1360 photos | Posted by old mart on 28/04/2020 20:22:40:
If anybody is interested, I have succeeded in getting the toolpost to bits, pictures of its guts here: . I would be interested, but every image link there returns: Invalid File Specified ... So presumably one needs to be a member MichaelG. |
old mart | 29/04/2020 13:04:06 |
Here are the pics:
old mart | 29/04/2020 13:13:06 |
4655 forum posts 304 photos | It is a clever design using a hurth coupling to align and spring loaded balls to hold the post while the coupling is being tightened down. I think the post can also be locked in any of the angles allowed by the number of coupling teeth. Differential threads in the central column and at the bottom of the toolpost lock and unlock the post. The internal parts which have to be realigned are marked as such. |
Michael Gilligan | 29/04/2020 14:12:06 |
![]() 23121 forum posts 1360 photos | Posted by old mart on 29/04/2020 13:04:06:
Sorry, I forgot that their new format won't allow viewing unless logged in, I hope it can be remedied. Here are the pics: . That’s brilliant ... Thank You It looks a beauty MichaelG. |
