terry callaghan | 23/04/2020 10:28:05 |
237 forum posts 10 photos | Hi chaps. I am a bit worried about the regulator control connections on a Martin Evans Columbia locomotive I am working on. The regulator is the twin popper type that is mounted on the front of the boiler within the smoke box. A control arm 56mm long complete with a 4mm face square formed end, extends to just outside the smoke box. The control arm needs a clockwise turn of 45* to fully open the regulator. Onto this square is fitted a connector as per the picture. My worry is that the connecting area is very small with only a very small locking pin to hold both together. |
Nigel Graham 2 | 30/04/2020 00:16:15 |
3293 forum posts 112 photos | The square looks to be smaller than the rod can accommodate, unless that part visible is actually a sleeve carrying the shaft inside it. Perhaps more to the point, it looks a bit short rather than too small. I'd suggest it ought end flush with the face of the operating-arm for maximum strength and contact area. |
