Carriage lock from bits and pieces
Simon Barr31/03/2020 19:10:47
34 forum posts
18 photos
Due to the abundance of time there seems to be in the current climate I decided I would dismantle all the slides on my mini lathe and reassemble it with care and some mods.
On my to-do list for a long time has been a carriage lock, so that's what I've been making today. Later once some shim arrives I'll be replacing the carriage retaining plate adjustment screws and just shim them instead. As well as replacing the screws holding the plates with studs and nyloc nuts instead of cap head bolts to hopefully make putting it all back together easier.
The carriage lock is made from some bits of plate I had hanging around and wasn't really made with any precision in mind, aside from it fitting together and working . The thinner plate is 5mm and the bolts are stainless, not sure how thick the other plate is. I also had to replace the smaller cap head with a button head as it caught on the bed webs. It appears to work OK but until everything is back in place I won't know for sure.
Simon.
Journeyman31/03/2020 20:12:18
1257 forum posts
264 photos
Good job but does the bit sticking out not interfere with the tailstock if you need it up close?
Simon Barr01/04/2020 16:46:37
34 forum posts
18 photos
Posted by Journeyman on 31/03/2020 20:12:18:
Thank you. I don't think it will get in the way to any significant degree. Here's a photo with the tailstock too. The carriage still has space to move further towards the chuck and is butted up against the tailstock in the picture.
Simon
Journeyman01/04/2020 20:23:08
1257 forum posts
264 photos
Excellentsmiley
