ratchetless drive
john valks | 21/02/2020 09:19:24 |
3 forum posts | hi everyone, has anyone made a successful lubricator drive, that has stood the test of time, and not given problems after just a few hours running? if so info, please.... |
oldvelo | 22/02/2020 03:17:24 |
297 forum posts 56 photos | Hi John Please post more details as to the end use of the lubricator. I.E. Lubricant amount and viscosity continuous or intermittent delivery Etc. Eric |
john valks | 22/02/2020 16:03:38 |
3 forum posts | Hi Eric, the type is for the 5" g 9F. and is of the ball and wedge, clutch drive. I have made several,, they run but are unreliable in a short time, either slipping and no delivery, or jamming up. so I am going back to ratchet and pawl.. you can see one being built on utube,, on account. No23mk2. part 66, 67, & 68 john |
oldvelo | 23/02/2020 20:38:20 |
297 forum posts 56 photos | Hi John Working in industry I worked on machines that had a sprag clutch fitted. They come in all sizes with the same dimensions as a Ball Bearing. possibly one of the very small ones would fit the bill. Took a peek at you tube Not a good idea to make the outer in any old steel it will FAIL even in a short time. The whole thing needs to be made from hardenable steel and properly hardened and tempered. The units I worked on had given thousands of hours service in harsh conditions. Eric Edited By oldvelo on 23/02/2020 20:40:55 |
John Rutzen | 24/02/2020 08:29:38 |
411 forum posts 22 photos | I have made a couple according to the drawing by S. Purinton in ME. It's just a wound spring round a 1/4 shaft and another attached to the arm. The spring grips one way and releases in the other direction. Works very well and costs next to nothing. |
