Myford Dividing Head
Needing Dimensions
Jeff O'Neill11/12/2019 19:25:46
7 forum posts
Could someone with a dividing head for the Myford 7 send me dimensions of some parts (spindle diameters/length etc.) so I can make a similar one for my South Bend?
Namely:
Diameter of overhead support bar.
All Diameters and Length for Spindle (Is it a #2 morse taper?)
Dividing head shaft diameter/length.
Distance between centers for support bar and spindle.
Thanks!
David Davies 811/12/2019 22:06:29
202 forum posts
Jeff
overhead bar 1" dia, 12" long
spindle 6 1/2" long, 2mt, 9/16 through bored.
maximum distance from spindle nose to overhead bar centre arm 6 1/2".
i would have to strip the spindle to get all diameters, threads and keyway dimensions, suffice to say that the nose is a std Myford, then the main body, then a plain collar, 1 5/8 dia, a threaded collar with a locking grubscrew and pad 1 1/2" dia, the 60T gear and finally the second threaded collar,g/s & pad, 1 3/8" dia.
plain collar 1/4" long, threaded collars 3/8" long.
hth
PS body 3 5/32" long (well it is on mine!)
Edited By David Davies 8 on 11/12/2019 22:12:22
Jeff O'Neill11/12/2019 22:55:45
7 forum posts
Thank you so much David! Could you clarify a bit?
6.5" spindle - that's overall length?
If so- what is the length/dia. of the spindle thread/thread base/wider boss? length of casting at spindle? What is the diameter of the spindle at the last threaded collar?
6.5" maximum distance from spindle nose to overhead bar centre arm - Does that mean clearance (center of spindle to bar (add 1/2" for center to center distance?) What is the diameter of the 60t gear?
Hopper11/12/2019 23:37:47
7881 forum posts
397 photos
If you want to make your own dividing head for a small lathe, it might be worth taking a look at GH Thomas's Versatile Dividing Head. Full drawings are in his book "Workshop Techniques". It appears to be a bit more robust and of course versatile than the Myford item. You can buy the castings and gears and worms from Hemmingway Kits or make your own. I fabricated the body from welded up steel sections and used a Myford 60 tooth change gear for the worm wheel and it works a treat. There was a series of articles in MEW last year about it. Worth a thought anyway.
Jeff O'Neill12/12/2019 00:06:28
7 forum posts
Thanks for the ideas! My use being watch wheels I am not too concerned about capacity. The Myford design would work well mounted to the milling attachment I already have.
David Davies 812/12/2019 20:42:13
202 forum posts
Jeff
I took my DH to bits to check sizes etc. It was fortunate that I did as I found I had left the woodruff key out so the gear was only held by friction. Severe bo***king for that!
I have uploaded photos which should give you enough detail to make your own. The Myford spindle nose dimensions are given in several threads here.
However I have to agree with Hopper that the GHT VDH kit is a neater alternative plus the design allows for enhancement to permit differential dividing and can therefore be used to produce gearwheels with prime numbers of teeth.
HTH
Jeff O'Neill12/12/2019 20:57:51
7 forum posts
David
That's perfect, thanks! Goodness that Thomas book is pricey.
David Davies 812/12/2019 22:09:02
202 forum posts
Jeff
The current edition of "Workshop Techniques" includes 'Dividing and Graduating' (£12.95 in '94) and 'Building the UPT', (£10 in the same year)so the price isn't so bad in my opinion. It's well worth a read.
Cheers
Jeff O'Neill12/12/2019 22:20:40
7 forum posts
I didn't realize it was still in print. Went to Amazon and the only one listed is 94 USD (70 GBP) though I see now I can find it for less.
David Davies 812/12/2019 22:40:16
202 forum posts
£26.95 from Amazon UK and same price from TEE Publishing,
Just noticed a Boo Boo on the outer nut, I have written 1" x 18 but this should read 7/8" x 18.
Will revise photos.
More haste less speed!
thaiguzzi13/12/2019 09:34:11
704 forum posts
131 photos
Posted by David Davies 8 on 12/12/2019 22:09:02:
Jeff
Cheers
Anything written by GHT is worth the money, and the education.
Hopper13/12/2019 09:41:45
7881 forum posts
397 photos
How are you going to make your indexing plates and drill all those holes in the right place? (800+ of them on the three plates for the Thomas dividing head! Not sure on the Myford?) Or do you have a rotary table etc already?
If you can't or don't want to make your own worm and wheel, they are available cheap these days on Aliexpress like this one here LINK
Edited By Hopper on 13/12/2019 09:46:01
Michael Gilligan13/12/2019 11:09:19
23121 forum posts
1360 photos
Posted by Hopper on 13/12/2019 09:41:45:
I’ve just had a look at this page: **LINK**
https://www.myford.co.uk/acatalog/Myford_Dividing_Head_and_Plates.html
That makes Tony Jeffree’s DivisionMaster [or one of the subsequent homages] look like a bargain buy !!
Hopper13/12/2019 11:51:54
7881 forum posts
397 photos
Youch. But it's not the plate that costs the money, it's all those holes. Not only do you have to drill the 812 of them, but then you have to chamfer each one -- on both sides! And then if you have perfectionist tendencies as some of us do, you have to deburr the outer edge of each chamfer just gently.
But the fun of trepanning a 4" disc out of a square of 1/4" steel plate makes it all worthwhile! One of the more exciting things I've done in the lathe. Just like parting off a 4" diameter, only on a curve.
Edited By Hopper on 13/12/2019 11:58:17
Michael Gilligan13/12/2019 13:50:47
23121 forum posts
1360 photos
Posted by Hopper on 13/12/2019 11:51:54:
Youch. But it's not the plate that costs the money, it's all those holes. […]
Very true
But with a DivisionMaster and a stepper motor, you need neither the plates nor the holes
MichaelG. angel
Edited By Michael Gilligan on 13/12/2019 13:51:29
Jeff O'Neill13/12/2019 14:57:32
7 forum posts
I am going to adapt a set of these: **LINK**
John Hinkley13/12/2019 16:58:55
1545 forum posts
484 photos
Or, if you don't live in the U.S. and/or have deep pockets and short arms , try these identical ones from Chronos at £48.
Dividing plate set
(Just a satisfied customer.)
Hopper13/12/2019 23:07:21
7881 forum posts
397 photos
Hoho. At those prices it's not worth making your own - unless you particularly like drilling small holes. Smart move.
Does the HV4/6 use a 60 or 90 tooth wormwheel? And I wonder if you can buy them as spare parts and use them in a dividing head?
The reason I ask is I have obtained very cheaply a set of castings to make a second GH Thomas dividing head and to fit my "new" Myford lathe. The first, fabricated, one I made was to fit the old Drummond lathe with a different centre height. Would be nice to avoid robbing the plates etc off the old one to make the new one.
Jeff O'Neill14/12/2019 01:39:37
7 forum posts
HV6 is a 90:1 ratio (haven’t seen individual parts for the rotary table). Plate holes- Plate A- 15, 16, 17, 18, 19, 20, Plate B- 21, 23, 27, 29, 31, 33 Plate C- 37, 39, 41, 47, 49
Hopper14/12/2019 03:06:33
7881 forum posts
397 photos
Thanks. Looks like I could use something like this Worm Gear
At $28 for what looks like two steel worms and two 90T worm wheels in bronze it's cheaper than I could buy the bronze material locally.
On my first dividing head, I used a 60T Myford change gear with a modified profile worm to fit. Works ok but point contact only. A proper worm wheel would be luxury for Mark 2.
Then I'd have to build a rotary table just to use the extra worm gear in the set above.
Edited By Hopper on 14/12/2019 03:10:35
