Change gear guard
vic donnelly | 10/12/2019 19:37:11 |
![]() 4 forum posts | Hi Marischal, I see in the photo of the Fortis parts that you have the change gear cover. As mine is missing I have to fabricate (mig weld) one. If I send you the postage could you take a template of end so that i can cut one from 16g steel. With the help from yourself and many others I have sorted my gear problem. thanks again. Vic Donnelly. |
Neil Wyatt | 10/12/2019 20:00:26 |
![]() 19226 forum posts 749 photos 86 articles | Posted by vic donnelly on 10/12/2019 19:37:11:
Hi Marischal, I see in the photo of the Fortis parts that you have the change gear cover. As mine is missing I have to fabricate (mig weld) one. If I send you the postage could you take a template of end so that i can cut one from 16g steel. With the help from yourself and many others I have sorted my gear problem. thanks again. Vic Donnelly. Hi Vic - to contact a forum member direct, click 'message member' under any post. Delete the member name that comes up (unless it's the person you want to contact). Start typing the member name that you do want to contact and you will get a list to choose from (it gets more specific as you add letters). Hope that helps, Neil |
vic donnelly | 10/12/2019 20:48:22 |
![]() 4 forum posts | Thanks for that, I will give it a try. Vic. |
