EMCO Rotary / Indexing table
Raphael Golez01/12/2019 18:18:55
167 forum posts
153 photos
Hi can someone help with the manual for the Emco 6 inch Rotary Indexing table. I believe the gear ratio is 40:1.
I understand that you can rotate the main worm gear out of engagement and make the table free to rotate but what puzzle me is the lock pin on the back left side. Is this just to lock the table? There is a separate table lock located on both side though. I opened the back cover plate and this locks a smaller gear, would this be direct indexing instead? If so its near impossible to tell the gear tooth engagement. If anyone who is familiar with this mechanism can please shed more light.
Lastly, can someone help with the plate indexing chart on this. I understand that it would likely be the same as any standard 40:1 but it would be good to see and compare info on the WWW.
Thanks in advance,
Raphael
Edited By RAPHAEL VAL GOLEZ 1 on 01/12/2019 18:20:12
Joseph Noci 101/12/2019 20:23:56
1323 forum posts
1431 photos
Hello Raphael.
I have some zipped BMP image files of the FB2 manual, in which the rotary table is well described.
The images are not great, but are legible/usable.
PM me with your email and I will email them to you.
The 'Lock pin' you speak of is used to 'pin' the rotary table in fixed indexes - if I remember correctly - in 15degree increments, in the perimeter of the rotary table. If using the index discs or dividing plates, that lever is pulled out and rotated to the disable position, so that you can index incrementally. The other two levers are to lock the table in position while machining.
To turn the table freely, loosen and back off the Cap Screw seen near the worm shaft exiting the table block. Then rotate the worm away from the table gear by rotating the dividing plate counter-clockwise.
Joe
fix typo
Edited By Joseph Noci 1 on 01/12/2019 20:25:17
Raphael Golez01/12/2019 22:20:23
167 forum posts
153 photos
Thanks Joe,
I have seen your work on this table with your indexing motor and adjustable grip tru style chuck mount. Really top notch.
Thanks for the clarifications. I will use this purely for indexing manual work. Do you have the chart for this? Or I can use a generic 40:1 chart?
I will PM you my email. Thanks in advance!
Cheers,
Raphael
Jeffery Morris14/09/2023 19:04:26
3 forum posts
Joe,
I know this is an old post, but I have a couple of questions regarding the lock pin. I looked at your pic's and when you added the stepper motor it looked like you removed the handle and locking pin parts. you wouldn't happen to have pic's of them, would you? I picked up a v10-p lathe and this rotary table was included. it has a plug where the handle should be. i found the handle in the toolbox but it appears broken and I don't see anything in the hole. I'd like to see the parts that make up this part of the assembly.
thanks
jeff
Joseph Noci 114/09/2023 22:51:18
1323 forum posts
1431 photos
Hello Jeff.
I will have a look tomorrow. I don't believe I took photos of those parts, but I may have a manual somewhere.
Joe
Joseph Noci 115/09/2023 08:01:44
1323 forum posts
1431 photos
Hi Jeff,
I don't have photos I fear - there are part breakdown docs on the web, google will find them, but most are in French or German, and the part drawings are not very clear it seems...
This photo shows where the pin - item 9 in parts list, impinges on the point ringed yellow. the pin is screwed in, rotating the eccentric which snugs the helix up against the ring gear to take up play and backlash. The red ring is the surface that is clamped in the table body, by cap screw item 16, preventing the eccentric from rotating. To relieve the helix from contact with the ring gear, loosen cap screw 16 and rotate the eccentric away from pin 9, and the helix rotates away and free from the ring gear. Pin 9 slide in the slot ringed yellow, 'up' towards the top end as the eccentric is rotated, Pin 9 keeps the eccentric from pulling out of the table.
For interest, some div. head calculators...
Div head spreadsheets1
Div head Spreadsheets2
Another Calculator
edit- smileys...
Edited By Joseph Noci 1 on 15/09/2023 08:02:37
Jeffery Morris15/09/2023 14:03:00
3 forum posts
Joe,
Thanks for all the information. I was actually looking for info on this part of the parts diagram:
Here's my broken piece that I have:
Parts 5,6,7,and 8
Jeff
Joseph Noci 115/09/2023 15:54:01
1323 forum posts
1431 photos
Sorry about that - without reference to the actual parts it becomes anyone's guess...
See photos below of the part - if you need a dimensioned drawing, let me know, I will see what is possible..
Michael Gilligan15/09/2023 16:06:57
23121 forum posts
1360 photos
Wow !
… a cunningly designed stress-raiser if ever I saw one surprise
Jeffery Morris16/09/2023 16:19:42
3 forum posts
Joe,
thank you so much!! those are the pics I was hoping to see. Now I understand how it works!!
thanks again!!
Jeff
