Warco GH1224 Wiring Diagram
And then it went Bang
Trevorh18/10/2019 09:40:20
316 forum posts
89 photos
Hi, Hoping someone has access to the wiring diagram for the Warco GH 1224 Lathe,
Pressed the start and it went POP and the breaker tripped out, No magic smoke escaped so I am assuming for now anyway that it has suffered a dead short somewhere
And like all owners I have the lathe up against the wall so now tonight I have to lift it clear to get access to the control box at the rear
Luckily I have an engine hoist and chain blocks so it shouldn't be the end of the world to move it out
I am sure it will be obvious once I gain entry to the electrics but thought it might safe a little time if I can look at the circuit first
Thanks
Trevor
Howard Lewis18/10/2019 10:01:03
7227 forum posts
21 photos
If you have the operators manual, there should be a wiring diagram towards the back.
If not, try contacting Warco. They will probably E mail one to you, and provide help on your problem.
Trevorh18/10/2019 10:21:11
316 forum posts
89 photos
Morning Howard, Yes I had the manual but it has gotten misplaced in the mists of time hence the request
I will try warco and see
thanks
John Hinkley18/10/2019 11:16:55
1545 forum posts
484 photos
Judging from pictures only, the Warco 1224 bears a distinctresemblance to the Grizzly G4002 lathe. If you have no luck with Warco have a look at this, taken from the Grizzly manual. (Obviously there are differences linked to the U.S. 110V supply and there is also a manual for models produced prior to 03/14.)
Trevorh18/10/2019 11:29:09
316 forum posts
89 photos
Thanks John, its better than nothing
So first stop check the mains fuse, the rest is quite straight forward to follow
cheers
trevor
Trevorh22/10/2019 09:26:04
316 forum posts
89 photos
So first Thanks to those who helped
once I had pulled the lathe clear and gained access it was the main QF1 breaker that had tripped
I disconnected the motor and checked but it was fine
Checked for loose connection - none
Checked the loads being pulled - all fine
checked mechanically - all fine and free
so its a mystery for now
I reset the breaker and put the lathe back together and its running fine
but what worries me is that it tripped for a reason and that reason has not gone away or fixed its self so it will be back.
Trevor
Mike Poole22/10/2019 09:52:43
3676 forum posts
82 photos
It’s difficult and time consuming to find a fault that may not even exist so I reset and then see where we are, I have come undone on occasions, the breaker suppling an 11kW drive had tripped so I reset, the bang was deafening and it did clean the dust off the fan, we now knew that we were definitely replacing the drive so much time was saved and when you lose a car for every 55 seconds that you are down then time saved is important. Breakers do not only trip because of an electrical fault, vibration and mechanical shocks can trip them. I once had a mysterious fault tripping a 250A breaker but the load was nothing anywhere near capacity, I noticed that one of the incoming phases was rather warm and as it was below the overload heaters it was enough to trip them eventually, no damage had been caused so just tightening up cured the intermittent tripping.
Trevorh22/10/2019 10:24:38
316 forum posts
89 photos
Hi Mike, This is the assumption I am going with that a certain set of circumstances came to align and caused the breaker to trip, the C15 breaker is more than capable of handling the in rush and I only ever have 1 piece of kit running plus some lighting both on different circuits and protected
what worried me was that it also took out my main breaker for the shed that's why I was convinced it was a dead short somewhere
oh well just have to wait to see if it returns and if so try to deal with it
trevor
Trevorh22/10/2019 10:24:39
316 forum posts
89 photos
deleted double post
Edited By Trevorh on 22/10/2019 10:25:28
not done it yet22/10/2019 10:32:44
7517 forum posts
20 photos
If it actually went ‘pop’, there was certainly something awry. Something, I would suggest, momentarily made contact with an earth potential. A chafed Live wire is most likely, I would think. Either rubbed against the case or against a an adjacent neutral conductor.. The other ’non-electrical’ fault might have been an evaporated spider or such-like?
Trevorh22/10/2019 10:53:15
316 forum posts
89 photos
Hi NDIY looking around it could very well have been a spider touching where it shouldn't
I checked all of the wires for scorch marks - not easily done in such a small control cabinet but as I say all of the wires/cables checked out fine and looked ok
Hope the spider enjoyed the tingle before it went pop - serves the little bugger right
trevor
SillyOldDuffer22/10/2019 11:10:12
10668 forum posts
2415 photos
Failure of a suppressor capacitor would explain the symptoms. The poor things are connected directly from Line to Neutral and from Line and Neutral to Earth. Although specially rated for this purpose (X and Y), they do go pop.
They fail by causing a short circuit, but it's only temporary because the capacitor's innards vaporise like a blown fuse. The brief short is plenty enough to cause a trip, but because capacitors usually die open-circuit everything appears normal when power is reapplied.
The purpose of the capacitors is to stop any Radio Frequency excrement produced by the machine being broadcast via the mains wiring. They stop the machine blotting out radio, tv and communications services.
It's a good theory, except John Haines' Hinkley's Grizzly Diagram doesn't show any suppression capacitors! Possibly there are some in the Control Panel circuitry.
Edit, silly mistake corrected thanks to John Hinkley!
Edited By SillyOldDuffer on 22/10/2019 11:24:53
John Hinkley22/10/2019 11:19:08
1545 forum posts
484 photos
Dave,
Don't blame John Haines. That was my contribution in response to Trevor's original request as.nobody had come up with a diagram specifically for his machine.
John Hinkley
wink
Trevorh22/10/2019 11:40:42
316 forum posts
89 photos
When opening the back cover I did find this photo which shows the schematic is slightly different in that I have a couple of breakers and not a fuse or contactor
Trevorh22/10/2019 11:42:45
316 forum posts
89 photos
But by putting the schematic that john posted with my schematic it made it easy to understand how it had been wired
so a very useful piece of information
trevor
Trevorh22/10/2019 11:45:30
316 forum posts
89 photos
Also I couldn't see any form of suppression on any of the contactors, I have uploaded photo's of the insides in an album,
unfortunately they have ended up upside down and I can't rotate them
either way as usual this forum came up trumps
trevor
