Walschaerts valve gear, is it self starting?
David Bothwell 1 | 30/07/2019 18:09:43 |
204 forum posts | Please excuse this question in advance! I would like to know if Walschaerts valve gear (on a locomotive model) is self starting, or to put it another way should the loco start from any position (of the valve gear)? I presume it does on full size, Mine won't!! |
J Hancock | 30/07/2019 18:24:06 |
869 forum posts | Simple answer, yes ! But, not unknown for a full size locomotive to have to 'reverse' first , before pulling away in forward gear i.e. dead spots can exist if timing slips. |
Jeff Dayman | 30/07/2019 18:25:18 |
2356 forum posts 47 photos | Are the wheel quartered on the locomotive? Meaning are the crankpins on the driving wheels on one side at 90 degrees to the crankpins opposite? This is what makes the engine self start or more accurately prevents the engine stopping at dead centre of either cylinder. If the engine can stop on dead centre of both cylinders it probably will not self start under any circumstances. (regardless what valvegear is used). |
David Bothwell 1 | 30/07/2019 18:32:47 |
204 forum posts | Thanks Jeff and mr Hancock, loco has been running but due to return crank movement it has stopped, revolves about 260 degrees" |
