Trevorh | 08/07/2019 14:23:04 |
![]() 316 forum posts 89 photos | Hi All looking for comments on the following equipment collections/cnc/products/ My son is looking to get into CNC for his model making comments please regards Trevor |
Trevorh | 08/07/2019 14:38:11 |
![]() 316 forum posts 89 photos | Is this any good for machining acrylics and poss Aluminium or soft metals?
thanks |
Ian Parkin | 08/07/2019 15:14:04 |
![]() 1174 forum posts 303 photos | I would say not its as cheap as a cnc can get and still work theres no software with it...mach 3 is £120 ish or the free mentioned the motor will drive you mad with the lack of power and noise soft wood ,foam but no metals at all not too sure about acyrilics and it has a very small work envelope
Trevorh | 08/07/2019 15:28:44 |
![]() 316 forum posts 89 photos | Thanks Ian, Glad we checked before he spent his money,
Thank you for the comment
Pleased I asked the question
regards trevor |
fizzy | 08/07/2019 15:47:13 |
![]() 1860 forum posts 121 photos | This is a link to the air cooled low end version of what I have - **LINK**
they are very well made from 10mm ali plate for the uprights.
Trevorh | 08/07/2019 15:48:27 |
![]() 316 forum posts 89 photos | Ok So I have spoken to my son and the "working Envelope" isn't an issue based on the above what would be a reasonable entry level type of machine to go for? The programming side of things isn't an issue as he is a professional Computer programmer by trade Thanks Trevor
Trevorh | 08/07/2019 15:50:18 |
![]() 316 forum posts 89 photos | Thanks Fizzy you obviously type faster than me...
cheers for the link |
fizzy | 08/07/2019 15:51:34 |
![]() 1860 forum posts 121 photos | this is the one I have - cant see how they do it for the money, very impressed with it and i use it solely for brass **LINK** |
fizzy | 08/07/2019 15:55:08 |
![]() 1860 forum posts 121 photos | and here is a video of me using it to drill holes in one of my burners - I had 100 to make so needed a hands off solution. Only snapped 2 drills so far and that was through sheer stupidity - not short of that! Pendle Steam Boilers CNC drilling |
Jeff Dayman | 08/07/2019 15:55:19 |
2356 forum posts 47 photos | Hi Trevor, Often with machines of this type, and 3D printers, there is a large Youtube community posting about the specific machines. If you search on youtube with the make and model you will likely find LOTS of good info about capabilities / good points / bad points before you buy. One thing I have noticed about cnc routers at the low end of the cost scale is that the motors look like ordinary Johnson-style DC plain bearing units with an adapter collet chuck tacked on. The bearings in ordinary DC motors (intended for fans or small appliances) are not designed to take heavy side or end loads as they would see in cnc router cutting or milling. I don't think the bearings in these motors would last long, especially with plunge cuts / end loads since the thrust brgs are minimal if present at all in a lot of common DC motors. If you can find a router with a belt drive to a separate spindle (preferably ball or roller bearing) then the motor will likely last far longer and the cuts will be cleaner too. With a separate spindle you might be able to rebuild / tune / improve it or get an upgraded one if problems occur and the youtube community responds. For 3D printers for example, there are many "hot rodding" performance improvement kits for various modules of the machines, shown and reviewed on youtube. |
Trevorh | 08/07/2019 15:59:30 |
![]() 316 forum posts 89 photos | perfect this is exactly what I needed - I will pass the above onto my son for further investigation
cheers |
Former Member | 08/07/2019 16:48:25 |
[This posting has been removed] | |
Trevorh | 09/07/2019 14:28:09 |
![]() 316 forum posts 89 photos | Barrie thank you, my son is now reviewing the alternative machines but has stated he is tending towards having a go at constructing his own..... Could/should be interesting
thank you to all that have commented
regards Trevor |
Baz | 09/07/2019 15:03:11 |
1033 forum posts 2 photos | Fizzy what size holes are you drilling? |
Trevorh | 09/07/2019 15:22:36 |
![]() 316 forum posts 89 photos | I think he is wanting to engrave and work with acrylics but not sure He lives over on the IOW so I dont get to see him often hence not sure what he is trying to achieve
Thanks |
fizzy | 09/07/2019 20:43:59 |
![]() 1860 forum posts 121 photos | Hi Baz - they are 1.5mm with a bit too fast feed rate. Slow the feed right down and 6mm is good.
