One Sided Fastener
Vic07/07/2019 11:46:37
3453 forum posts
23 photos
New to me!
It seems like some other conventional fasteners now also use the five lobe design.
ChrisB07/07/2019 12:08:41
671 forum posts
212 photos
Similar to fasteners used on aircraft. The key design looks much better than the Hi-lock hex drives which have a tendency to round off - meaning you have to drill out a titanium fastener in some awkward place and position!
John Haine07/07/2019 12:09:31
5563 forum posts
322 photos
The mounting brackets for the "movable vehicle-activated signs" (a/k/a speed warnings) we use round our villages are fixed to speed limit sign posts using jubilee clips that have a 7-sided socket screw!
old mart07/07/2019 19:59:54
4655 forum posts
304 photos
The Hi Lock that I used had the aluminium snap off heads on the nut, the hex socket was only needed in case the bolt rotated while the nut was tightened, not to unscrew the assembly. I believe there are more conventional nuts for certain applications.
Theft of aluminium road signs, cast iron manhole covers and bus bars from electricity substations is common these days. Probably getting less as China is cutting back on its scrap metal imports, so the price is dropping.
Vic07/07/2019 20:18:11
3453 forum posts
23 photos
Posted by John Haine on 07/07/2019 12:09:31:
Mole grips on the outside of the screw?
ChrisB07/07/2019 20:52:03
671 forum posts
212 photos
Posted by old mart on 07/07/2019 19:59:54:
Depends, when using Hi-Locks in structural parts and repairs most of the times it's an interference fit, so the hex drive on the collar most often than not snapped off before the fastener could turn - given that the hole was reamed to the correct size beforehand.
Where hi-locks are used to retain brackets floor beams etc hex nuts are used not collars. Sometimes the fastener rotates with the nut and then you'll need the key.
